The Emachines were running the Phoenix BIOS. 4 Beeps in Phoenix could indicate a RAM issue. To insert
it again, hold the memory module at a 45-degree angle and insert it into the
now empty memory slot. Gently press down on the module until the retaining
clips click into place
It can be a simpe issue of the RAM chip came loose, and should just be re-seated. Turn your machine upside down, and locate the MEMORY cover. These can usually be removed using a small star /phillips screwdriver.
Once opened remove
the memory module by gently pressing outward on the retaining clips on both
sides of the memory module until the memory module is released and tilts
upward. Then, pull the module out of the slot.
or the RAM has been corrupted and you should replaced the RAM chip- it used DDR SDRAM 333MHz
We already tried repositioning with no avail. I'm asuming that my hard drive has finally crashed. Thank you so much for your quick responce. I appreciated your time.
You welcome. But I don't think it is the HDD, just try with another RAM chip. Good luck though
