Question about JVC AV-27D302 27" TV
JVC Interiart 27" TV
We have dropped the remote and does not work anymore, chked batteries, look okay inside remote.
The tv is set on to the DVD station can we manually change the channel to TV and not DVD. On the top right of the there is volume, channel and a on/off buttons.
Can some one help.??
Andrew Tinker
    Master:
  • JVC Master
  • 427 Answers
Hey there Andy l rekon ya busted yer remote so best git on down to the store an git yerself one a them universal remotes for xmas.
Posted on Nov 17, 2017
4 Suggested Answers
Kimi
  • 277 Answers
SOURCE: On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Posted on Nov 30, 2005
talon1973
  • 17 Answers
SOURCE: JVC I'art flatscreen TV remote doesn't work
This maybe a sticky one.
#1. Original remote may have something spilled in it or may have dirty battery contacts.
First check battery contacts and make sure it's not corroded. Clean with small brush and baking soda. Let dry thouroughly and replace with fresh batteries.
If this isn't the problem or you tried this, then move on.
Next, Get these materials. A cloth, 50% amonia and 50% water sulution two small blad pocket knife and a philips head screwdriver.
Some remotes will have screws holding remote covers and internal board and others do not. If your remote have screws, remove them all. If not, then start prying your remote apart with your pocket knives. Do so very carefully as not to damage anything inside.
Next, lay down remote button facing down, and remove circuit board. Now, take note of rubber button pad(s) position(s) and remove them. Place these pads in your water - amonia solution.
Clean all cntacts and rubber pads, and remote housing. Now before reassembling remote, look at the IR lamp at end of board. Look underside and notice solder joints. Wriggle lamp and see if solder joints move. If so, have this resoldered. Now reassemble remote and give this a try.
#2) Codes may have not been entered right with your new universal remote. Go through all codes again just to be sure.
#3) IR receiver in set maybe damaged or not receiving power to it or the microproccessor has quit responding to the remote commands. Have a good technician check into it if problem is evident that your set has simply stopped responding to remotes.
Good luck,
Jason.
Posted on Jan 09, 2009
jdvillanueva
  • 2098 Answers
SOURCE: JVC 27" TV model do not know what are the codes
Hi Roger,
You didn't mention the brand of your universal remote control. Anyway, here are the universal code for JVC Tv.
JVC Codes: 013/ 054/ 055/ 060/ 065/ 067/ 089
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 15, 2011
TV is on but when is off after sometimes and next time it can't on but it is on sometimes
The cat is not sleeping on the remote by any chance?
My set sometimes does not come on. The reasons generally are:
1) I have turned off the power at the wall.
2) I have not pointed the remote at the TV but rather at the DVD player.
3) Someone pressed DVD on my universal remote and that took it off the control settings for TV.
4) The battery is loose in the remote after someone dropped it.
5) The battery is weak.
6) Someone turned off the TV manually using the switches on the side.
7) The little computer in the TV has become confused by a user trying to switch from channel to channel before each channel is "found" and displayed to screen. You turn it off and back on and proceed slower.
8) The station transmitter is off the air due to power failures.
Aug 26, 2015 | Televison & Video
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Aug 06, 2012 | Televison & Video
New remote control not working.
Have you checked whether the battery (cells) is fine? If you have a SW Radio, switch it on, tune it to a place where there are no stations, take the new remote near to it and press various buttons. If you can listen to clicking noise, the remote is ok. The problem might then be in the sensor. A capacitor leaky or dry.
Aug 02, 2012 | LG 42LD450 42 in TV
Plasm tv remote control will not work have put in new batteries to no avail the tv works fine without the remote it,s just annoying to keep having to get up to changs stations
Remote issues and answers:
If you are using a "universal" remote do not expect it to if it evenprograms to have all the functions you need or had with the"original" remote.
If you are searching for codes for a universal to program it: GOOGLE the modelnumber of the remote for "codes" or if you do not have the ownermanual GOOGLE the model number of the remote for "manual".
Some remotes have a search feature that allows you to try all codes on at atime.
Universal remotes are far from UNIVERSAL.
If you have a remote that does not work at all--have it tested first: a remotetester is used at many electronic repair centers and places like Radio Shack for example.
Point remote at the tester and press any button and a strip or light willflash----some digital cameras will also react on display screen to this.
If dead check the battery/s and the connections where they go and if only somebuttons have to be pressed hard the unit may have had something spilled on it:it can be taken apart and cleaned in a proper way to resolve this.
If it has been dropped it can also be taken apart to see if the infrared LED/sat its sending end have come loose from the circuit board inside the remote.
Lastly is the best argument for an original remote is on many sets even if itprograms it will just not have all the needed functions the original one had.
Many companies especially on units with DVD OR VCR built in change the codewith each model and or year as most of these are not actually made by thecompany whose name is on the unit.
Let me know if you have further questions and I will try to help.
Mar 30, 2012 | Samsung Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
Hello
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Remote does not work
Did you drop the remote lately my dog loves the plastic and knarls and slobers on them. Go buy a cheap replacement and try it
Mar 24, 2010 | LG 37LG30 37 in. LCD HDTV
Remote tv compatible codes
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
codes are
LG/Goldstar 1(default), 2
zenith 1,3,4
samsung 6,7
sony 8,9
hitachi 4
good luck
Apr 04, 2009 | Televison & Video
JVC AV-27D302 27" TV Logo
224 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
