Question about Canon ZR90 Mini DV Digital Camcorder
ZR90-Shutter off Purchased camera in 2004. Last December it started showing a black screen in the middle of a shooting and not responding. Under "camera settings" menu the "shutter" is lit as "not working." The shutter opens, allowing the image to come in, at the will of the camera. We are wondering if this can be fixed or if we should just purchase another camera. Who can we take the camera to for them to take an honest look?
  • thanh
    thanh Oct 14, 2013
    i had a same issue in 2004 when i was travel to my country , when i came back to canada i found out that was a problem from canon , and they fixed it for free and i still using it until now
    New Friend:
I went back o future shop to exchanged another firewire and it works with my program (Flipbook Imovie and Iphoto
Posted on Oct 19, 2013
As the user said above several models had been affected by loose wires connecting the ccd. My zr70 was affected by this, I contacted Canon and an RMA was set up. Repair time was about 10 days and was delivered back working. http://tinyurl.com/3cra86 Contact Canon, I had no problem with this even thought I purchased my Camera in 2004.
Posted on May 29, 2007
Model zr90 has a problem in CCD try to check to Canon service center.
I have a Canon PowerShot SX 10 IS. In Manual mode shows only black screen with icons. In Auto mode everything is fine.
Dear Olia,
Just a quick check on your camera. You have a focus issue so check the settings for the ISO - increase the value, eg. 800 or above and reduce the shutter speed. You can do that by the quick access dial (wheel) facing you. There are four direct access menus in a criss-cross direction. One is assigned to shooting mode - single, multi, timed etc. The other direction will have macro, standard, telephoto etc. the 3rd direction will (towards right) will take you to the ISO settings and the last will take you to the shutter speed settings.
you manipulate the ISO and shutter speed and see your screen will brighten up and the subject will be clear. Refer to the picture attached.
Hope this helps.
Oct 18, 2015 | Canon PowerShot SX10 IS Digital Camera
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
There is no image showing up on the display. There are function icons on the screen and you can go through the menu but when you point to shoot a picture the screen is black with the icons.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 24, 2010 | Canon PowerShot S2 IS Digital Camera
Can't viewb the LCD screen when shooting a picture! it's just black
The D60 works as SLRs have worked for half a century, showing the image in the viewfinder until you press the shutter. The LiveView feature which shows the image on the LCD screen is a rather recent development on DSLRs, unlike on point&shoot cameras. The D60 does not have this capability, which Nikon introduced with the D3 and D300.
Sorry if this wasn't the answer you wanted to see, but there it is.
Oct 04, 2010 | Nikon D60 Digital Camera with 18-55mm lens
The screen just shows black, the lens works it flashes for pictures but all pics are black
Verify the shooting mode. Sound like you have underexposed images, maybe due to a too fast shutter speed or too small aperature...
Jan 29, 2010 | Kodak EasyShare C913 Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
AF will not work, manual shots do not show up on CF card
Your shutter curtain is broken. Shutter mechanism last for around 5000 shots, you need professional service to fix it.
Sep 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Canon ZR90 Mini DV Digital Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
