Question about AcerPower 8000 PC Desktop
Can't remove the CPU cover to install a network card
I'm trying to remove the cover to my Acer 8000-333A CPU so I can install a network card for DSL internet access. I recently inherited this computer from a friend who'd had a wireless card installed. I've unscrewed 3 spring-loaded screws from the back of the computer, and found the lock/unlock switch at the top left, but I can't get the cover off to reach the network card space. Please help! Thanks.
    Genius:
  • 1,913 Answers
Unlock the switch then pull the cover in back direction.
Posted on Dec 25, 2008
I have a Acer Verton E430 Desktop. Suddenly upon restart after the initial beep and Acer splash screen returns to restart with one short beep and process continues on and on.. Advise how to solve.
One short beep can be DRAM refresh failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Dec 02, 2014 | Acer Computers & Internet
Suddenly network card stopped work. can't connect internet
Try This: Unplug the power to the DSL Router for 20 seconds then plug it back up. Remove the power cord and battery from the laptop, then press and hold the power button for 30 seconds. Turn the laptop over and look for the screw on the Wireless Card Cover. Remove the screw and the cover (it may be a number of screws depending you your system) then unplug the antenna cables to the wireless card (normally a black and white or black and gray cable). Remember which cable goes where before you remove them. Remove the screw that holds the wireless card in the slot, then remove it. Put the Wireless card back in the slot and secure it with a screw. Put the antennas back on the wireless card and then the cover. Put the battery back in, plug in the power cord and reboot.
If the system still does not find your wifi card, the card might be bad.
*** Sometimes the wireless card will be under the keyboard or palmrest instead of the bottom of the computer.
Apr 05, 2012 | Computers & Internet
My Acer kav60 WIFI turns off and it dissapears. I have tried the on/off button with no luck. Rebooting does not turn it on either. Then when least expected it comes back. Help!
sounds like your wireless network card is failing or has a bad connection. suggest you power down your laptop, turn it over and remove the access panel for the memory and network card. remove the memory to make easier access to the wireless card and check for loose connections to the board and the antenna. if this looks good take the card out, use an eraser and lightly scrub the gold contacts on the card itself. when all the contacts are shiny again reinstall and test again to see if the issue is resolved. (do not install the cover) if it is resolved, install the cover and if not you can buy a replacement for this for under 20 dollars on eBay. make sure you purchase one that is listed as buy it now and new in package. the drivers should but do not have to be part of the sale. here is a good listing.
http://cgi.ebay.com/WiFi-Bluetooth-PCI-E-Network-Card-Acer-Aspire-One-/130407544956?pt=LH_DefaultDomain_0&hash=item1e5ce5387c#ht_2367wt_905
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 21, 2011 | Acer Aspire One PC Notebook
How do I know if this cpu has a network card?
The Dell GX270 small form factor has an integrated NIC card that is built into the motherboard.
May 15, 2010 | Dell OptiPlex GX270 PC Desktop
Where do i install this sound card?
Install it in to CPU. Remove the CPU cover, Find the PCI Slot(White colour). Plug it , close the cover and turn on the PC
Jan 18, 2010 | Sabrent 6-Channel 5.1 3D Surround Sound...
Hi , I have an Acer aspire 4736z laptop. The wireless internet gets disconnected every 10 minutes. not sure where is the problem, can you help?
the internal wireless card has either been told in network settings to shut down every 10 mins or is faulty and needs replaced if you take the cpu and ram cover off the bottom the card with the grey and black (usually)wires attched to it is the wireless card also u might wnt to try rolling back the drivers or updating them even from acers website
Oct 02, 2009 | Acer Aspire 4720 Notebook
Just replaced power supply on cpu. When I turned the computer back on the modem stopped working the dsl light flashes green then red. As soon as the computer is turned off the dsl light is solid and I get...
It sounds like your network card was damaged by a power surge, most likely what brew the power supply too. When you power up the PC now the network card tries to start and kills the network line going to the router, when PC is off the card does not short and the router works like it should. You should be able to put a new network card in a open slot in the pc and connect that one to your router.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Computers & Internet
Install ethernet wireless in pci slot
Yes you should have a few white color slots in there and the card will just slide into the slot. There is nothting on the inside to connect to other than teh slot.
Jan 02, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Need assistance starting up my acer aspire computer m1641
Timegatewood,
That would depend on how you would like to get the internet connection to your ACER.
Option 1
Ethernet line
Benefits: Faster connection, easier setup, more secure
Cons: Wires must be physically routed requiring drilling through walls or passing through vent openings.
What you'll need:
Router
Cat 5 ethernet cable from router to ACER and to your HOST PC
Ethernet network interface cards (NIC) in both PC's
any length of cable exceeding 100-150 feet will likely need a network Hub to boost signal strength
Option 2
Wireless
Benefits: Wiless acces to host PC(no drilling through walls etc.) can connect multiple PC's by simply adding a wirless card to new PC
Cons: prone to interference, less secure, setting up security protocols can be cumbersome
What you'll need:
Wireless Router/Access Point(AP)
Wirless adapter for remote PC (ACER)
Someone who is knowledgable about Wireless security to setup the firewall settings in the router.
OK so now that you have the options you can decide which is best for you.
Ethernet : If your willing to drill holes or pass through vents this will give you a faster connection
Wireless: This makes for a no mess/no fuss connection but at the expense of security and potential interference from cordless phones etc..
If you need help setting up your Network connection after you decide which you'd like please feel free to ask.
Thanks
Dave
Nov 26, 2008 | Acer Aspire M1641-U1521A PC Desktop
AcerPower 8000 PC Desktop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
