Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
I had to force quit my Simpletech SP-U35/500 now it won't show
Up on my mac book. I was running garage band off of the simple tech, which I've since been told was possibly part of the reason it froze in the first place. I gave up and force quit after half an hour of the pinwheel of death. When I started it up again the drive seems to be operating from what I can observe, but it won't show up on my desktop. I have 320 gigs of samples and sound bites on there...bummer!
Am I screwed or is there a way to deal with this?
thanks,
Mikhail
How to display Monitor image from mac book through samsung SP-H03 pico projector?
It's not that easy. The SP-H03 accept VGA input through the D-Sub connector. Mac book does not have this output directly. So you need another piece of adapter for the MAC Book to provide VGA output. It would come out from your Mac "Display Port /orThunderbolt port".
Another way is to use a USB to VGA adapter for Mac.
Jan 18, 2013 | Samsung SP-H03 LED DLP Pico Projector
HOW TO TRANSFER DATA FROM SIMPLE TECH HARD DRIVE TO MAC
Yes Mac and Windows use 2 different and incompatible hard drive formats. However, there are many files that can be opened between the two. Mostly media and some docs. Try uploading to somewhere like MS Windows Live Skydrive or simply email. Then download. This is a quick fix. I heard you could use file sharing, but that requires a network. Even burning to a disc should work.
Aug 31, 2012 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
SimpleDrive 500GB 96300-41001-160 shows no activity
I think you bought a piece of junk especially if you cannot hear the hard drive spin when you connect the power supply.
I suggest you get a tech savy friend to check out this hard drive for you.
Apr 13, 2012 | SimpleTech SimpleDrive Hard Drive
My hard drive quit showing up on my mac desktop and i am not able to access any of the files. the red light still turns on when i plug it in but thats it. i tried plugging it into a pc to see if it would...
It sounds like the hard drive died.. If it won't show up on two different operating systems, then it's more than a simple computer reboot. You may want to try a local repair store and see if they have any luck backing up the drive.
Jun 01, 2011 | SimpleTech SimpleDrive 160 GB External USB...
SimpleDrive External Hard Drive
If you click on the apple logo, top left of scree, select force quit and then click eject.
Disconnect the drive and reconnect it. Wait for the drive to show in Disk Utility and select Mount for use in your Mac. Not Dos!
Sep 30, 2017 | SimpleTech SimpleDrive...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Simple tech signature mini 169 GB
how do I reset my format from a Windows to a MAC
Oct 25, 2008 | SimpleTech Signature Mini 160GB External...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Correct website.
Yes, I do believe that the "CL" is a color code.
http://www.simpletech.com/commercial/products/signaturedriveportable.php
Nov 20, 2007 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
200 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Phil Whisenant
Phil Whisenant
Steve Allison
Steve Allison
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
