Question about Akai PDP4206EA Television
How do i fix my t.v.
How do we get to the vertical position
  • ladyzart Apr 08, 2008
    how do you hit the -?
    Champion:
  • 217 Answers
You have to use a code on the remote, press the mute button first and then 1-8-2 and then the power button, it should bring up the service menu, look for the h-position and v-position
Posted on May 27, 2007
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
I have an Error 2 that happens when trying to scan a document. It makes a clunking noise. How do I fix this? Thanks in advance!
E2 error means is a paper jam.
Solution 1
Turn the printer off, then on again. Sometimes, when Pinter turned on, the position of the wheel is not correct, causing the error E2. By turning off the printer and then turn back, the position of the wheel will return to normal. This way I've ever done and it worked.
Solution 2
You turn the sensor vertically, as opposed to clockwise. By rotating the sensor vertically, roller wheel position to be shifted, so it will return to normal position. Rotate the sensor vertically, until you hear the sound (clak) of the wheel roller.
Nov 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I cant get my c2050 out of the doorway.ive tryed getting it trhue the dooeway no angle will work. i cant find anything to detach to take it apart. any suggestions?
A) HOW TO LOWER THE TREADMILL FOR USE
1. Refer to drawing 2 above. Hold the upper end of the treadmill with your right hand as shown. Using your left
hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock
knob. Note: You may need to push the handrail to the side slightly.
2. Refer to drawing 1 above. Hold the treadmill firmly with both hands, and lower the treadmill
Watch thsi video:
http://www.youtube.com/watch?v=kDNegYEnrSc
Before folding the treadmill, adjust the incline to the
lowest position. If this is not done, the treadmill may be permanently
damaged. Remove the key and unplug the power
cord.
1. Hold the treadmill with your hands in the locations shown
at the right.
Raise the treadmill about halfway
to the vertical position.
2. Move your right hand to the position shown and hold the
Sep 25, 2011 | Nordic Track NordicTrack Treadmill, A2550
E140 error
Lens vertical home position sensor error 1
- Definition - [B]
The lens vertical home position sensor remains de-actuated 3.0
seconds after the lens starts returning to the home position.
- Possible causes -
· Lens vertical home position sensor defective
· Lens vertical drive motor defective
· DC power supply board defective (check FU303)
May 18, 2011 | Ricoh FT5832 Copier
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps
Apr 15, 2010 | Bakers Pride P-44S Oven
Whindshield wipers stuck in a vertical position
This is an easy fix. Likely ice got on your windshield and froze your wipers to the glass then when turned on moved out of position. Take the cover off the base of the wipers and loosen the bolts. Put them down all the way and tighten. When wipers are turned on when frozen to glass the gears want to move but cant and loosens at the base. Please let me know if this does not help and will look into it further but this is probably it. Thanks
Jan 02, 2009 | 2005 Chevrolet Impala
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Rca 24V511T
take123, problem is with vertical circuit not eprom, could be bad capacitor supporting the IC or the IC itself is bad, that type of problem needs a tech because once it`s fixed you will probably have to go into the service menu and re-adjust the vertical positioning, this of course will require the info in the service manual which you can`t easily obtain, questions? e-mail me back, BMW Rider
Nov 30, 2007 | RCA F36650 36" TV
Televison & Video Logo
50 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
