Question about Dell Inspiron 6000 Notebook
Installation? I am trying to install some programs into my computer but the computer keeps popping up an error message basically telling me it CAN NOT install something new because i'm in the middle of another installation. I don't remember the last time I installed anything so how I can find out what I am supposedbly installing to stop that installation so I can install what I REALLY want to install.
Hai,
first instal program software from the site provided by dell install in d/drive and strat your program if any case error pops up retry by software from intel
Posted on Dec 25, 2008
Tablet shut down in the middle resetting. How do I finish the reset process?
Cry. Seriously, remove the drive and copy off of it any and all files that you want and need. Then format the unit and reinstall the operating system and programs from the backup disks that you have. No backup?
Now you are really ******* - see if you can get set from notebook manufacturer. If not check with your computer literate friends to see if any of them have OS installation disks.
Mar 26, 2016 | Computers & Internet
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Am getting 1721 errors on my computer, can you tell me how i can fix it ?
    Here you go. This is long winded but should fix you up.
    Error 1721 is a common problem for many different Windows systems, shown when the installation you're trying to perform develops a problem and needs to be fixed. If you have this error, it's recommended that you're able to first fix any problems that could be inside your Windows system, and then cure the specific issues that the Windows Installer program has on your PC. This tutorial is going to show you exactly how to do that...
    This error will typically show like this:
    • Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor.
    The problem with this error is actually caused by a very simple issue - the Windows Installer program that is used to install the various files & software onto your PC is actually damaged or corrupted & preventing your system from installing the program you want. This can be caused by a number of problems, including everything from having corrupt registry settings to the Installer program on your system being damaged. To fix this, you first need to make sure that Windows Installer is okay, and then get rid of any further system errors on your computer.
    The first step to resolving this error is to "register" and "unregister" the Windows Installer on your system. This is a program which installs all the programs that you want onto your PC, and is constant on every Windows installation. The problem that often causes error 1721 is the way in which Windows often cannot read the Windows Installer program, because it's not "registered". Registering a program basically tells Windows where to look for it on your system, and it's often the case that this stored reference is either damaged or deleted by accident. To ensure this is not a problem, you need to be able to type the following into your system:
    • Load up "CMD" (click "Start" > Run > type cmd)
    • Type msiexec u/unregister
    • Type msiexec /register
    • Try reinstaling the program you wanted to
    If you try this and find it does not work, then it's recommended you then use a program by Microsoft called the "Windows Installer Cleanup Utility". This is a new program which basically cleans up all the settings and options associated with the Windows Installer program; meaning that if you have any problems with the Windows Installer on your PC, they should be fixed. You may also wish to install Windows Installer 4.5, which will basically upgrade the Windows Installer program on your system, which should resolve many cases of the 1721 error.
    It's also highly recommended that you use a "registry cleaner" to fix any of the errors that are on your Windows system. A registry cleaner is a type of software tool that basically scans through the registry database of your PC and fixes any of the problems that are inside it. The registry database contains all the settings, files and options for Windows, and is where everything from your most recent emails to your desktop wallpaper are kept. It's basically like a library for your system which is continually being used to help your software run correctly. Unfortunately, the registry is continually being damaged & corrupted, leading it to become highly ineffective and erroneous. To ensure this problem is not causing the 1721 error, you should clean through your system with a registry cleaner tool.
    Sep 11, 2010 | Dell Computers & Internet
    ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
    Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
    Mar 15, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    123CopyDVD.exe has stopped working......
    First, Uninstall your program using Add/Remove Program in Control Panel.
    Start Menu -> Control Panel -> Add/Remove Programs
    Note: Be aware of shared files don't remove them, it will affect other programs that use that file
    After Uninstall, restart your computer
    Then start again, proceed to installation of your program.
    Jan 26, 2010 | Navarre 123 Copy Dvd Gold for PC
    Get fatal error message after installationof
    Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
    Aug 18, 2009 | HP Office Equipment & Supplies
    Error 1935 occured during installion of microsoft office
    This issue may occur if a Microsoft .NET Framework file is being used when you try to install Office 2003. For example, this issue may occur if the Mscoree.dll is being used when you try to install Office 2003.
    To work around this issue, restart the computer. Alternatively stop Windows Installer.
    If these actions do not resolve the problem, repair the existing installation of the .NET Framework. Alternatively troubleshoot .NET Framework installation issues.
    For more information about how to restart the computer and about how to stop Windows Installer, click the following article number to view the article in the Microsoft Knowledge Base:
    308096 (http://support.microsoft.com/kb/308096/ ) BUG: Error 1935 during install of the .NET Framework For more information about how to repair an existing installation of the .NET Framework and about how to troubleshoot .NET Framework installation issues, click the following article numbers to view the articles in the Microsoft Knowledge Base:
    306160 (http://support.microsoft.com/kb/306160/ ) How to repair an existing installation of the .NET Framework 824643 (http://support.microsoft.com/kb/824643/ ) How to troubleshoot Microsoft .NET Framework 1.1 installation issues in Windows XP or in Windows 2000 For more information, click the following article number to view the article in the Microsoft Knowledge Base:
    926804 (http://support.microsoft.com/kb/926804/ ) Error message when you try to install a 2007 Office program: "Error 1935. An error occurred during the installation of assembly component" APPLIES TO
    • Microsoft Office Small Business Edition 2003
    • Microsoft Office Standard Edition 2003
    • Microsoft Office Student and Teacher Edition 2003
    • Microsoft Office Professional Edition 2003
    • Microsoft Office 2003 Personal Edition
    • Microsoft Office Basic Edition 2003
    Please donot forget to rate these suggestions.
    Mar 19, 2009 | HP Pavilion dv2000t Notebook
    Trouble Launching
    Did you receive this software with a camera or printer as freeware? That version is probably not compatible with your version of the Mac Operating System or the CPU you are using, one of the two. In your basic menu you may have a program called Boot Camp. This emulates Windows. If you can launch that you may be able to install your program from there, just point to the Windows version of photoelements.
    Version 2.0 is discontinued and there is no support or patches for it available at Adobe. See the Adobe Notice at the end of my relpy to you. This installer version you have cannot be fixed unfortunately since patches are not available.
    You can download a trial version of 6.0 that retails for 89.99 should you decide to keep it. The web page is located here. http://www.adobe.com/products/photoshopelmac/
    "Adobe Photoshop Album 2.0 was discontinued on June 30, 2006.
    Note: Although this product has been discontinued, it remains protected under copyright laws and the End User License Agreement.
    We recommend Adobe Photoshop Elements as an alternative to Photoshop Album 2.0. For product information on Photoshop Elements, see the Adobe website"
    Jun 20, 2008 | Adobe Photoshop Elements 2.0
    Error message during installation of motorola 4.0 phone tools
    your DLL - direct library link file seem to be corrupt....you may need to install over the pervious version.
    Apr 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
    Error Code 2753
    be sure to completely remove any programs having to do with sprint smartview reboot computer and then plug the air card in the computer and run the setup from the pop up window that states new device found reinstall the smartview connection manager through the preinstalled drivers located in the device itself then after installation is complete reboot and then connect issue is fixed
    Jan 26, 2008 | Computers & Internet
    Dell Inspiron 6000 Notebook Logo
    258 people viewed this question
    Alun Cox
