Sportcraft Tx2.5 Tx 2.5 Treadmill Motor Speed Controller Board Circuit Control Logo
Posted on Sep 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tx 2.5 is on 3 - Sportcraft Tx2.5 Tx 2.5 Treadmill Motor Speed Controller Board Circuit Control
ernesto cuadra
Level 3:
Top Expert:
  • Sportcraft Master 12,223 Answers
  • Posted on Sep 10, 2012
ernesto cuadra
Sportcraft Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080420
Points
34431
O.k if you have problem with a control board you can find from
www.treadmilldoctor.com
go and buy it.
God bless you
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Zone 2 must be on to hear zone 2
there are 2 ports for sub woofer, try using the other sub port.. I dont have to use zone 2, and not sure it even has a zone 2 sub port.... I use zone 2 for a cd player and speakers on the deck.. no sub woofer
Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator Please enter your ZIP Code: CANTRELL SUPPLY INC. 2918 SOUTH COOPER F-2 ARLINGTON TX, 76015 (817)465-9121 11.1 miles BRANCH VACUUM & JANITORIAL SUPPLIES, L.P. 12895 JOSEY LANE #122 FARMERS BRANCH TX, 75234 (972)247-5838 15.7 miles FORT WORTH SHAVER & APPLIANCE 1900 MONTGOMERY STREET FORT WORTH TX, 76107 (817)335-9970 16.3 miles AMERICAN VACUUM CO. 5545 W. LOVERS LANE DALLAS TX, 75209 (214)357-8419 18.2 miles KIRBY CO. OF DALLAS 4118 MAPLE AVE DALLAS TX, 75219 (214)526-7951 19.0 miles BRUNER KIRBY CO., INC. 5608 MC CART AVE. FT. WORTH TX, 76133 (817)292-8421 19.4 miles VACUUM DEPOT 5359 WEDGEWOOD FT WORTH TX, 76133 (817)292-4472 19.4 miles MODERN AMERICAN MAINTENANCE 8545 CAMP BOWIE WEST FORT WORTH TX, 76116 (817)244-0919 19.9 miles ALL VAC, INC 4451 LOVERS LANE DALLAS TX, 75225 (214)521-2558 20.2 miles KIRBY CO. OF DESOTO 104 N. HAMPTON ROAD DESOTO TX, 75115 (972)223-4029 23.8 miles AAA VACUUM CLEANER CO. 9845 WALNUT HILL LANE DALLAS TX, 75238 (214)348-1620 25.0 miles BROADWAY VACUUUM 4401 BROADWAY BLVD GARLAND TX, 75043 (972)240-7971 31.1 miles THE VACUUM DOCTOR 500 NORTH GALLAWAY - STE. 10 MESQUITE TX, 75149 (972)329-1104 31.4 miles CHAMPION VACUUM, INC. 8809 LAKEVIEW PARKWAY #128 ROWLETT TX, 75088 (972)463-2755 34.3 miles VACUUM & SEWING DR. OF TERRELL 811 WEST MOORE, SUITE E TERRELL TX, 75160 (972)563-0330 49.8 miles var prm = Sys.WebForms.PageRequestManager.getInstance(); prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity); prm = null; function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() { var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity'); var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter')); elAct.style.width = bounds.width + 'px'; elAct.style.height = bounds.height + 'px'; Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y); } Locating Stores... progressbar.gif
Top Sportcraft Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
