Question about Zenith XBV443 DVD Player/VCR
Zenith xbv443 vhs portion not working after connecting it to new lcd tv
Hi, I used an s video connection to attach my dvd/vcr to my lcd television. after attaching another cable for audio, the dvd works great but the vcr shows no picture or sound. THe blue Zenith screen stays on the tv. there is a small light on the machine (progressive scar)? - if i turn that off should the vcr work? also, have a cable box, tv and dvd/vcr machine. ive connected the cable box directly to the tv and the dvd/vcr to the tv directly. will i be able to tape shows or would i need to reconfigure? thanks!
snakehead
  • 1074 Answers
SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Posted on Apr 08, 2007
SOURCE: TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Actually, I have the solution. Press and hold the stop button on the dvd side, (left side), for 10 to 20 seconds.
Posted on Feb 27, 2008
SOURCE: DVD/VCR stuck in Progressive scan mode
omg.. I was going to go spend money and buy a new one.. Ty you so much..
Posted on Aug 11, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Posted on Jun 06, 2011
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
I am trying to connect DVD/VHS player to my TV without connecting to dish. How do I get the video player to work. What settings, etc...?
the back of the dvd/vcr will have outputs labeled dvd/vhs output, use this out put to go to the tv. The input will be labeled as input 1 or 2, with the input button on your remote select the input you plugged into and your good to go.
Aug 31, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the...
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Regards,
BElectric
Feb 17, 2011 | GoVideo Go Video DVD/VCR Combo
How to use my Zenith VRB4215 VCR with my new LG
please refer to this picture: http://www.retrevo.com/r/375bh427/3/Connections+for+your+VCR#q=Zenith+VRB4215
Rather than use the method in the picture above you should use the audio L+R and video OUT on your VCR and connect these three to the color matching audio IN and video IN ports on your television. The colors are red, and white for audio and yellow for the video. If you do not own a cable like this simply pick one up at radio shack they will know exactly what you need. The pictured method will work also but the picture and sound quality will not be the best possible.
Remember you are sending data OUT from the VCR and IN to the TV
Oct 29, 2009 | LG 47LH90 47 in. HDTV LCD
VCR doesn't work when installed between cable box and TV
a simple way is to get an AV switch .
you may like to try connecting it with different cables
May 07, 2009 | Televison & Video
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Zenith XBV443 DVD Player/VCR Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
