Question about Dual Electronics CECT P168 Cellular Phone
Cannot Find Network!
My carrier is AT&T and i try to set the Network to that but when it cannot find it, it says "failed to register"
Can anyone help me out??
noavatar_s.gif eleitz
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
At&t WAP Setup
***First Step***
1.Main menu --> Select Services
2.Select Data Account --> Select GPRS
3.Select the first entry
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to WAP@CINGULARGPRS.COM
9.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Posted on Dec 25, 2008
Samsung galaxy fame mobile phone. Cannot make phone calls. States not registered on network
Is the phone locked to a specific carrier?
If your phone is unlocked, sometimes a firmware upgrade or restart prompts you to renter your unlock code.
Can you borrow a SIM card from a friend and test your phone, maybe your SIM card is faulty.
Check in your phone settings and make sure that the phone carrier is set to ‘auto’ and not set to a specific carrier, Bell, Rogers, AT&T etc.
Dec 02, 2017 | Samsung Cell Phones
Registering to a Network
Contact your carrier's Customer Service number. Sometimes, device IDs can change when devices are zeroed out, and if your carrier locks your account to a device ID, you may need to have the carrier reactivate your account and tie it to the new device ID.
Dec 11, 2013 | Nokia 6500 Slide Cellular Phone
I have a regular load on my SMART SIM card but it wont let me send a message.Why is that???
If we have the same problem try doing this. I guess you have receiving a red x-mark was it?
First, do a manual network search. Second, choose any network that is NOT your carrier Third, When it fails, select then your carrier Fourth, your BB should register the network afterwards
May 05, 2011 | RIM BlackBerry Bold 9000 Smartphone
I successfully unlocked my Samsung Impression SGH-A877. I put in the new sim card for my new carrier (in Japan) but when I dial a number I get the "emergency calls only" message. Does anyone know...
This can indicate that your SIM isn't registered correctly, go to settings menu and network option, look for search network or add network option, if your carrier is found try to register (this is a manual network selection), if your carrier is not found, maybe your phone can't work at your Japan carrier bands (maybe is 1200 or 1700 MHz) and your phone only supports most commonly used GSM quad -bands ( 850/900/1800/1900 MHz ), please ask your carrier if supports the mentioned bands.
Mar 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My blackberry curve says call failed everytime i try make a call
go into your options, Advanced options, Host routing table, hit the option key and select register now. this will reregister your phone on your carriers network, if that doesn't work let me know
Feb 08, 2010 | RIM BlackBerry Bold Smartphone
Sciphone fails to register with network, no bars, but sim card has contacts in phone?
First you need to make sure that your phone is actually working in the band that your wireless carrier uses. If your carrier uses a 850mhz. band and your phone is a triband without the 850mhz. band it will always says emergency and would never register. Borrow another Sim card that uses either 1800 or 1900mhz. band. If it register, then the phone is triband and your wireless carrier uses 850mhz. band. Another thing is to check the imei number, if they don't match, you need to fix'em. Compare the imei numbers (*#06#) with the one in the battery compartment.
Oct 03, 2009 | Cell Phones
Cant connect to internet
Are you connecting wirelessly or with a cord? if wireless, you need to make sure that you are selecting the same security setting as the connection that you pick in 'network settings'. If the option is 'none', then you need not worry about a password. however if it has a password, then you need to make sure that you type that password in (case sensitive). I had the same problem and this worked for me. hope this helps...please rate if it does....thanks
if that doesn't work try following these steps....
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Dual Electronics CECT P168 Cellular Phone Logo
160 people viewed this question
Top Dual Cell Phones Experts
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
