Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Detergent dispenser - Fisher Paykel dishwasher DD603
Can we use the dishwasher tablets in this model? There are 2 plastic posts in the dispenser which seem to bar the use of tablets. Don't have a manual.
  • Fisher and P... Master
  • 2,651 Answers
Manufacture does not reccomend using tabs, small amounts of powder, will work jsut fine
Posted on Dec 25, 2008
  • anne Brook
    anne Brook Apr 14, 2014
    my new F+P came with 2 tabs that fit but the ones I have don't. I had a F + P drawer dishwasher before and at that time they recommended powder. why did this come with 2 tabs if they still recommend powder
I don't know where to put the new Finish tablet in the Fisher and Paykel dishwasher. Where or what is the Dry Dispenser ?
Hello Susanna Davies,
Generally a round cap immediately next to the
washing powder dispenser...
Known as "FINISH" or "Jet Dry"... as it really does
keep spot off of your dishes & especially glassware.
Amazon com ishwasher dry agent Tools Home Improvement
I tried to look up Fisher & Paykel...
but without a specific MODEL NUMBER
I could not pull an OWNERS MANUAL to demonstrate.
look here for FREE documentation
ManualsLib Makes it easy to find manuals online
SEARS is the last place I would recommend buying parts
(but that has more to do with integrity & respect)...
Their parts, guarantees & prices are suddenly competitie
Dishwasher Detergent Dispenser Part Number 526860 Sears PartsDirect
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | Fisher and Paykel Dishwashers
Generally what type of detergent you use depends on what is recommended for the dishwasher. I am not sure which model of fisher and paykel dishwasher you have. But my opinion is that dish drawer type dishwashers work better with normal Finish powder detergent. It is not designed for tablets. The size of the wash space is small and it works on the principle of short and quick wash cycles. So the powerball is an overkill. Now about the streaking, this could be linked to the powerball but also you need to check if the rinse aid is present in the dispenser and also that you have selected the appropriate meter level for it being dispensed. 0 means no rinse aid and 5 is too much.;
May 01, 2013 | Fisher and Paykel Dishwashers
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Aug 07, 2010 | Fisher and Paykel Dishwashers
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel model dd603 - won't drain
Depends on Whether or Not you had the unit Professionally installed, The Drain Hoses are Designed to Stay their extra long Length, they act as a u-tube system using the center of gravity to help drain the unit, if you've cut them to short the water simply is unable to go up the lines because the drain pump is not strong enough.
Aug 07, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
This is simple you need a new Detergent dispenser fitted in the bottom drawer. cheers
Mar 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi- It sounds like the solenoid on the dispenser is not changing the water diverter to the wash portion (cup) of the dispenser. You most likely need a new dispenser. Probably best to have a Tech out to change it.
Mar 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here:
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
1,403 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
