Trying to set up my new toshiba note book, got to the create user name and password, then when it re booted it wont let me in saying wrong password, i cant figure it out can you help?
    Genius:
  • 1,913 Answers
I think u forgott your password also check there is caps lock is off then try.if yu failed u have to reset your password.when u power up the computer press F8 key then u see menu then u se safe mode press enter on safe mode.then clik on administrator .then if it want passsword password is blank.then go to my computer rightclik it thewn u see manage go to manage then local users and then u see your user name right clik it and reset password pls dont forgott password.
Posted on Dec 25, 2008
How do i scan and send to email
Scan setup. create a folder on c drive of computer example called scan. then share folder with everyone and make sure it has read/write permission. Then on copier push button says user tools/counter then system setting/administrator tools/ address book management /new program / enter a name then go to folder smb then browse for computer select it. then will ask to log in. which is log in name and password that you use to log on computer with. Note user name needs to be letter or numbers only no symbols or spaces. Example user name: scanner password: scanner123 then select scan folder and press ok then press ok again to save setup.
Sep 30, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Reset password for Toshiba L635
Here is a simple way to access Windows XP with Administrator rights and privileges if you have password protected your User account on your Windows XP system and can't remember the password(s) to login. Whenever Windows XP is installed on a system, it creates a default account called "Administrator" and by default this account is not password protected. Therefore, if you bought a brand name computer (such as Dell, HP, Compaq or Sony)or you have installed Windows XP yourself. You should be able to login to the computer through the unprotected.
You can log on as an administrator to assign a new password to your account. To do this, try Method 1.
Method 1: Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch on until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't press any keys (e.g. F8) during the boot-up the computer will startup normally.
If Method 1 is unsuccessful try Method 2.
Method 2: Reset Windows Password with SmartKey Windows Password Recovery.
Download SmartKey Windows Password Recovery from SmartKey Password Recovery Official site
Decompress the SmartKey Windows Password Recovery and note that there is an.ISO image file. Burn the image file onto a blank CD with the burner.
Insert the newly created CD into the locked computer and re-boot it from the CD drive.
Boot the PC with the CD Rom and Run the SmartKey, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
Dec 26, 2011 | Toshiba Satellite L635-S3040 Notebook PC
I need to create a "System Password" to the system. The BIOS only allows to create a password for the "BIOS". That is not the password I want to create. When the system boots up I would...
hare are a number of password changes that can be made
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can add change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps you
Aug 18, 2011 | MSI K9N6PGM2V2 Motherboard w AMD Athlon II...
Reset startup password
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password also if you want set a BIOS password
during the boot up process you will see on the screen for a short amount of time to press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab click the name of the computer administrator you can change the password there
you should make a note of any passwords and keep them separate to your computer incase of memory lapses
hope this helps
Aug 16, 2011 | Computers & Internet
I am msi laptop passwords problem. pls help me for msi laptop cr-400 ms-1451..I want to password chang software ..pls help me...how to bios password chang
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password also if you want set a BIOS password during the boot up process you will see on the screen for a short amount of time to press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab click the name of the computer administrator you can change the password there
hope this helps you
Aug 04, 2011 | Intel Motherboard
I want to change my password
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password also if you want set a BIOS password during the boot up process you will see on the screen for a short amount of time to press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab click the name of the computer administrator you can change the password there hope this helps you should make a note of any passwords and keep them separate to your computer incase of memory lapses
Aug 01, 2011 | Computers & Internet
RESET SECURITY PHONE
if you are refering to a password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
Jun 02, 2011 | Computers & Internet
Change password
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
Hope this helps
Mar 07, 2011 | Computers & Internet
Don't Know My Pass Word
When you boot up to the log in screen type in administrator to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
or
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Or it's a bit of a read
Passwords add a level of security to your computer. When sharing a computer with others, your customized settings, computer programs, and system resources are more secure when you assign a password to your logon name or user account name. The steps to perform this task differ depending on whether your computer is a member of a network domain or is part of a workgroup (or is a stand-alone computer). My computer is on a domain You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure. Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password. My computer is not on a domain If no password has been assigned to the user's account, a password will need to be created before it can be changed. For information about creating a password, click Related Topics. The steps to perform this task differ depending on the type of user account you have. If you have a computer administrator account Open User Accounts in Control Panel. Click your account name. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type your new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. If you have a limited account Open User Accounts in Control Panel. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type the new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. Notes A user with a computer administrator account can create and change passwords for all users on the computer. Users with limited accounts can create and change their own passwords, as well as create their own password hints. If a user with a computer administrator account changes the password for another user, that user will lose all EFS-encrypted files, personal certificates, and stored passwords for Web sites or network resources. Notes To open User Accounts, click Start, click Control Panel, and then click User Accounts. For more information about user accounts, click Related Topics. Related Topics
click start control panel user accounts on the users tab,click the name of the computer administrator you can make yourself the administrator of your computer there which will give you all rights to change whatever you want on this computer
hope this helps
Jan 22, 2011 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
