Echo Hedge Trimmer Throttle Cable Hc-1500/type 1e/type 2e Lhc-1700 17800105360 Logo
A
Anonymous Posted on Sep 09, 2012
How to repair echo hc 1500 throttle
Adjusting
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Mar 19, 2009
SOURCE: what would cause excess vibration in an Echo
Check for loose blade to case mounting bolts or cracked support bar.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
lnbn1975
  • 204 Answers
  • Posted on Oct 23, 2009
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Anonymous
  • Posted on May 29, 2010
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Anonymous
  • 59 Answers
  • Posted on Sep 24, 2010
SOURCE: how can i test the ign. coil on a echo HC-1500 and
pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Why no gas going into primer bulb
There is a hole some where check prime bubble
Echo hc-1500 service manual
here you go
https://www.manualslib.com/manual/909345/Echo-Hcr-1500.html
https://www.manualslib.com/download/909345/Echo-Hcr-1500.html
Jun 24, 2012 • Echo Garden
1helpful
Have no spark on my Echo HC-1500 hedge trimmer. Have replaced coil with new but still no spark. Have also by passed kill switch still no spark. What else can I try
Hi, have you tried a new sparkplug? Also did you set the coil to magnet airgap at 8 thou? Also when you say you by passed the kill switch did you do this by leaving the wire off the coil? Because if you did it at the switch end the wire from the coil may be chafed somewhere and earthing the coil. Hope this helps, regards Phil.
1helpful
6helpful
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
Oct 23, 2009 • Echo Garden
7helpful
9helpful
2answers
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
your engine type.
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
