Question about Pyle Dryver PLAD213 Car Audio Amplifier
1200 watt legacy amp not working right
Ok, my amp & sub's were working fine then i was trying to hook up some 6" neon lights to my amp & i unscrewed the ground,remote & power wires & then hooked them back up. Then my amp would cut in & out at a high level of volume or just not work at all at low volumes. So i unhooked the remote wire & cut a piece of it off & connected it directly from the remote wire hookup on the amp to the power wire & it worked fine, though it stays on all the time. So does anyone know what the problem is & is there anyway to fix it?
    Problem Solver:
  • 11 Answers
Your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Posted on Apr 15, 2007
I recently hooked up a new kenwood deck put new front and back speakers in. I hooked up a 1200 watt hifonics amp about to plug in my 2 15 inch rockford fosgate speakers rfz1412 and they dont play. All the...
Ok, so I am assuming that the other speakers are working, and it's just the subs that are not, right? If this is the case, start from the source. Make sure the RCA cables are plugged in and not crimped anywhere. Then to the amp, Did you check the gain levels on your amp. That is the knob next to the RCA input on the amp. Also, check the wiring to the subs. Make sure all your + are goinig to +. Sometimes in the "heat" of a good install, you just lose track of those things. When in doubt. Undo all your wiring and start from scratch. Good luck.
Aug 30, 2011 | Rockford Fosgate RFZ1412 Car Speaker
Legacy LA770 worked for 2 10" subs but not for 1 12" sub
if the protect light is still on with all speakers disconected then you have overloaded the internal ic and blown it beyound its ability to reset
sorry
Jun 25, 2010 | Legacy Audio LA770 Car Audio Amplifier
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Wiggle the positive wire to get power and have to unplug subs to turn car off
Ok it sounds to me that your remote wire is not hooked up right casue if you trun your car off then your amp should power down an when you trun your car on it should power up
May 07, 2009 | Car Audio & Video
I have two 1200 watt sony amps bridged red light on in one why?
If you are certain speaker isnt blown and you have correct phase wiring and so forth you have whats called a solder jump which is internal repair by dealer only! buy a new amp at dealer wholesale price here cheaper than having it repaired unless under warranty go here for wholesale pricing on almost everything audio wise:
www.godspeedaudioheaven.com
Jan 03, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
No power to subs
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
May 06, 2008 | Legacy Audio Blue Diamond LA1880 Car Audio...
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Pyle Dryver PLAD213 Car Audio Amplifier Logo
89 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
