Question about Sony Cyber-Shot DSC-T1 Digital Camera
I have a sony cyber shot, have changed the batteries and I power it on and it powersright back off
My camera was doing the same thing - replace memory stick fixed the problem.
Looks like faulty memory pulling down the battery voltage.
Posted on Jan 01, 2009
Every time i turn on sony cyber shot the screen states turn the power off and on again whats wrong
Hi change the battery and check it again if steel the same the spring that keep battery connected may need to stretchgood luck
Oct 19, 2011 | Sony Cyber-Shot DSC-S500 Digital Camera
Built in flash on Sony DSC-F717 will not open up. Have reset and checked all settings.
BAD battery !!The high quality Rechargeable Sony Cyber-shot DSC-F717 Battery [Non-OEM], It can provide extended power for your Sony Cyber-shot DSC-F717 digital camera, this battery is made specifically for your digital camera and to meet or exceed the original manufacturer specifications, we will ensure optimum performance saving you time and money.
Sep 04, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Sir, Shutter of my Digital camera Sony Cyber-shot DSC-P72 is not closing / return to original position completely. I have tried with changing the battery too. Every time that I do power on the massage...
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C91134&fes=true&mdl=DSCP72
Try doing a power reset:
Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C265373
Jul 23, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-shot Will not power up
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
TURN CAMERA ON SCREEN FLASHES cYBER-sHOT AND GOES
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 08, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Date and time mode
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESETbutton or Initialize option in the menu. These cameras require a manual power reset.
Sep 01, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
I have a Sony cyber-shot dsc-w30. When I turn it on the lens goes in and out, I get a message on the screen saying "access" then I get a message saying "turn power off and on again".
Sony maks good products and stand behind they product, but they do have a problem with the batteries , change the battery and i bet u will not have that problem
Aug 08, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Same as one that's been posted... When I change to picture mode on my Sony Cyber-Shot DSC-P73 it automatically powers off. By changing back to view mode it's possible to power on again. Not the batteries....
RESET your camera. Refer to your camera manual for reset instructions. It may require to push a reset button or check this link (copy and paste in your browser windows IE or Firefox):
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374
Aug 02, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony cyber-shot DSC-S500
If you open the camera up, whick I know is an intricate task, and take the screen down but don't unplug it, at the right bottom their is something that resembles a watch battery, if you can figure out how to get it off and find a replacement it will be fixed... This battery serves a a sort of memory power, even though you have batteries, this battery keeps the memory for the camera's software, so inturn without it the camera is dead in the water. this is fixable!
Dec 15, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
