Question about Acer Aspire 4720 Notebook
Acer 4720 wireless problem..
When i want to connent to the secure wireless..after i type the keys correctly...i cannot surfing internet because its show that the profile its not connect ...i have tried many times..but it still show the same thing..NOT CONNETED..what i have to do?
  • dheeraj dg Jan 20, 2009
    cant find wireless lan driver
  • nokerns May 11, 2010
    what is ur operating system? is it XP? just try to view the available wireless networks and type exactly the key. it should be automatically added as a profile.
Can no longer connect to home wireless intranet. Says I'm connected but when I try to get on it says I'm not. Yellow triangle w/black ! in it. Wireless light on computer base is constnatly
AuthenticationThat means you probably don't have the password or theAuthentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
May 29, 2012 | Acer Aspire 5742Z-4200 Notebook
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Cannot get the internet to work
May 08, 2012 | Computers & Internet
Hi i have acer aspire 4720z and it is not able to connect to wireless internet.However it showing connected to wireless network
Check that you have entered the wireless security key onto the laptop, may be this that is not allowing connection.
Jan 22, 2011 | Acer Aspire 4720 Notebook
Cannot create a wireless connection
More than likely it is not the key but either the encryption or the security type. Make absolutely sure that you are choosing the right type of security (WPA, WPA2, WEP) and the right type of security algorythm (TKIP or AES). Also note that versions of Windows earlier than Vista do not correctly handle WPA2. If that is the type of connection try to change it to WPA. WEP is weak and easily cracked.
Jun 06, 2010 | Computers & Internet
Lost signal on acer aspire 6530 lap top, dont know if my daughter has pressed a wrong button or switch ?
There is a little satellite icon next to the always blue (when turned on) skip to next (song) and stop (square) touch buttons. Put your finger on the satellite icon for a few seconds, then move off, a green message should come up on the bottom of your screen saying "Wireless LAN enabled", if it says "Wireless LAN disabled" then there is another problem with your connection.
When the wireless is enabled check that you're connected to the wireless network. Start > Control Panel > Network and Internet > Network and Sharing Center (in Vista) you should be able to see:
"Access Local and Internet"
If it's not connected to the internet try resetting your wireless router, if that doesn't work, check you have the correct network password. Right click the two little PC screens (icon) in the bottom left, in the new window right-click your network and go to properties. In the new window, "Security" tab check the settings and type in the correct network security key (password) again. Hopefully you will have a record fo the network security key or your problem will have already been fixed before you get to this point. :)
Sep 27, 2009 | Acer Aspire 6530-5143 Notebook PC
My laptop is acer 4720 when the wireless isnot show any wireless station
First u install wireless drivers after u will configration.First open the inernet explorer go to tools click on internet option and show the dilagbox click on connection and select second chekbox give ur net ip and port nomber.
Jul 11, 2009 | Acer Aspire 4720 Notebook
We have anew acer p.c, and cannot access the internet. it accepts the wep key. help. wireless linskey, 3 other p.c.s no problem.
What is the operating system of your laptop? Is it running Windows Vista or XP? Can you check if you're getting an IP address wirelessly?
Go to start>run>type cmd and then hit enter.
On the black screen type, ipconfig/all and see if you're getting an IP address similar to the IP address of the other working computers. If not, then that is the problem, that means that the wireless security that was entered on your new laptop is incorrect. To make sure that you entering the correct key, save your security key on a notepad and then copy and paste it on your wireless adapter settings.
Jun 27, 2009 | Linksys Computers & Internet
Internet connection
If you are worried that it is a Hacker then do not use WEP. Use WPA and do not use only words use symbols and numbers. But this seems like you have a router that is going bad. I would try resetting it to factory settings by opening internet explorer and typing in the box where you enter web addresses type 192.168.1.200 or 192.168.1 then you will find your router setup page and you will be able to reset your router to the factor settings. Another thing about securing your connection is that you must not use a WEP inscription and your WPA or WPA2 access code must not be only a word it must include other character e.g. #@$%^&*
Good Luck
Apr 16, 2009 | Arris SURFboard SBG900 802.11g/b...
Acer Aspire 4720 Notebook Logo
314 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
