Question about Akai LCT3201AD 32 in. LCD Television
Is it a Fuse or the Power Supply
When I turned on the TV (47" HCT Tv Model HLD-47FHD) this morning using the remote I heard a sound like a pop and I have no picture and my power light indicator is organe. When I normally turn on this TV the power indicator is green and when it is off the indicator is red. Do you think I have a bad fuse or power supply. Please assist. Thanks!
  • 4 Answers
It's not the fuse. Chances could be your PSU
Posted on Oct 13, 2017
SOURCE:
premtech
  • 934 Answers
SOURCE: Are you willing to fix a power supply for a Akai lct2662?
You may have inadvertently swapped one of the caps and didn't install it in the correct polarity... Or one or more regulators are also bad... Or there may be some more and severe damage caused by the swollen (popped) cap - especially if the cap was in the 100mf range or above...
Can't really quote something like that until I was able to see and test it. However, I will charge the same as our shop rate: $29.95 plus shipping for the estimate and based on the estimate if you choose to have it repaired I'll waive the $29.95 - shipping is repaired or not.
Bill
Posted on Jul 25, 2008
  • 2337 Answers
SOURCE: Blinking red light
It appears in all cases that the power supply needs to be service. The blinking light might indicate that there are shorted parts or the voltage is low or a combination of both.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
freetek
  • 5569 Answers
SOURCE: ESA Plasma PDP4294LV No video,sound
 checked voltages meter set to AC referenced to chassis VA, VE, etc no voltages.
Do not try to measure voltages on the primary side of the power supply with a meter; you may damage the meter and cause new damage to the supply. There are switching frequencies somewhere between 50,000 - 100,000 Hz and possible voltage peaks of several hundred volts.
Checking AC is only useful before a diode bridge that converts incoming AC into raw DC that is then chopped at higher frequency into an approximate HF AC, coupled to the secondary, then tapped and connected to more diodes to produce DC, finally regulated and sent on its way.
Your plasma set uses some higher voltages that could have caused the cracking sound they heard but the DVD player didn't cause the problem directly; maybe just caused the HV for the display to surge for a moment.
You may have additional fuses on the secondary side of the supply. If test points are accessible there, check for DC voltages and be suspicious of any fuse or test point that measures nothing at all.
I can't tell you which voltages to expect since that varies from one design to another but you should find several lower voltages such as 5 VDC for logic circuits and perhaps a 12 V point. The plasma's HV could be produced from a separate board fed from the AC line or get its supply voltage from the main supply. There aren't many standards to rely on here.
The most likely semiconductor failure would be on the secondary side and diodes come in many different packages, many cylindrical, some in the TO-220 package with a metal flange and mounted on upright aluminum heatsinks. These will have only two leads and there will be some in the same package with three legs. The latter can also be checked statically but unless you know what kind of transistor or regulator (look about the same) you are measuring, you will not be able to ferret out a defective one with any luck.
While you have the set open, check for any dust bunnies that can act as sponges, collect moisture and create a discharge path for higher voltages.
Posted on Dec 27, 2008
javswr
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
  • 1779 Answers
SOURCE: Insignia NS-27lcd tv won't turn on
Well, take the plug that goes to the inverter board out which has the 12v on it. Check the 12v again at the power supply. If 12v is low you can possibly have 2 caps bad, the values should be about 1000uf/35v or there abouts. They set close to the plug. If that doesn't work then replace the Power Supply because there are no service manuals for lcd p/s. plus nearly impossible to locate individual ic's. Try Shop Jimmy.com for the P/S.
Posted on Apr 30, 2009
HCT model HLD-470MD. Any idea what value C11 is on the power supply board, or where I might be able to get a schematic for the TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs are given.
Sep 24, 2015 | Televison & Video
Hct hld 42ma
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. This detail will have the code list document attached to every universal remote control. The brand name of the remote control isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control have setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Nov 01, 2013 | Televison & Video
NEED TV CODE TO PROGRAM HCT TV 47'' TFT LCD USING SHARP LCD TV REMOTE MODEL#GJ221
037,031,039,036 are the codes to check. If you wish to get more, check these links. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Televison & Video
Need code for hct tv using onn remote model#ona12avo58 to program47'' tft lcd tv model#hld-47omd
0092,0062,0048,0073 are the codes to check with HCT. If you wish to get more, check these links. http://electronicshelponline.blogspot.com/
Oct 07, 2013 | Universal Remote Control Televison & Video
Hitachi clu-4591av stopped working - popping sound
The power supply regulator section should be troubleshooted. The "Pop" sound you heard might be of a bursted electrolytic capacitor in the AC mains rectifier section inside the TV. All the related commponets, rectifier diodes, protection zener diodes etc:- should be checked before switch ON the TV further.
May 15, 2012 | Televison & Video
I have a HCT 32" TFT LCD HD TV, model number HLD
Your back light is probably out - it may have a bad inverter. Shine a flashlight on the screen and see if you can detect any color or images. If so, then the back light is out. Inspect the inverter for any bulging capacitors. They must be flat on top - if they bulge at the top, then that capacitor is bad.
Dec 12, 2010 | Samsung Televison & Video
Still looking for the remote codes for our HCT TV\ r\n MODEL#HLD-22HCB
you won't find one...had my hct tv for more than 2 years...direct tv cannot program remote....i just used both remotes
Oct 09, 2010 | Televison & Video
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Akai LCT3201AD 32 in. LCD Television Logo
73 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
