Question about Microsoft Xbox 360 Console
1 red light flashing
It had 2 flashing red lights on the right so I took it apart an replased thermal compound put it back together an got 1 red light on the left with a error E74 on the screen how do I fix this?
    Scholar:
  • 22 Answers
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours...........
Posted on Apr 09, 2009
2008 Chevy Silverado Signal lights work in the back but not the front
when last owner put leds in it sounds like they have messed arund with the wiring, i would suggest you check that.
Nov 03, 2016 | 2008 Chevrolet Silverado
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one spot.playstation will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
HELP... I have a big problem with my PS3. My system was okay when I took it apart for cleaning but i completely disassembled it and cleaned the dust. I put it back together and now it wont work! When I...
I fix PS3 Yellow Light of Death.
When you say you completely dissasembled it i guess you mean EVERYTHING?
Well did you make sure you plugged the battery back in? and Made sure all connections were placed back?
If you took off the heatsink and fan from the chips then that is why it switched off!
You should have put new paste on if thats the case!
The PS3 seems it is shutting down to protect itself from overheating and burning the chips!
The baby scratch should be ok unless it has destroyed a copper track?
Goodluck let me know how it goes and please rate!
Apr 08, 2011 | Video Game Consoles & Games
My ps3 recently got the yld and i looked up how to fix it myself. i took it apart cleaned it of all dust and applied the new thermal compound and everything else that your supposed to do. After i put it...
Almost 90% of ps3 can be fixed by new thermal Compound but you may need a new power cord either way id just send it to sony but im glad u tried i failed too trying to fix mine
Good Luck and Happy Gaming-Koscoe
Oct 15, 2010 | Sony Playstation 3 (PS3) Console
I have one red light flashing on my xbox 360. how can i fix it?
If you have a hard drive, clearing the cache might resolve the one red light error. Also, you can try to remove the hard drive and power on the Xbox 360 Console without the hard drive to see if the red light will still occur. If it doesn't appear it is the hard drive causing the error and needs replacement, if it does flash the red light still, it is a hardware failure in your Xbox already.
May 06, 2010 | Microsoft Xbox 360 Console
Hi ive just turned my ps3 on it stopped and went off now it wont play just got a red light when pushed it flashes green and blue the goes red when pushed again it flashes red help
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
Red light flashing/won't turn on
you are right about replacing the thermal compound between the cpu/gpu and heat sync. the gpu and cpu may need to be refolowed also. another tip is dont over tighten the screws. Tip: keep your ps3 flat do not keep it standing. when it is standing and heats up the thermal compound can start to move away from the heat sync. Keeping it flat will help extend the life PS3 at least from the overheating issue.
May 14, 2009 | Sony Playstation 3 (PS3) Console
Two Flashing Lights
it may be overheating depending on which 2 are flashing, which if its shutting itself down, im willing to bet thats what it is. make sure you've attached the heatsinks securely with the x clips and do yourself a favor and use some good thermal material like arctic silver. make sure the fan is securely plugged into the mainboard.
Aug 03, 2008 | Microsoft Xbox 360 Console
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
My xbox flashed a red light, and the screen goes black
I went with the eraser fix and it worked like a charm. Can anybody explain why using erasers changes things and makes the 360 work without the 3 red lights flashing? Just Curious!
May 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
69 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
