Question about Canon imageRUNNER C3200 Copier
IMAGERUNNER C3200N PRINTED DOCUMENTS LOOKS YELLOWISH
When i print the document the paper looks not pure white , it looks yellowish what could be the problem
  • corporatepro Dec 30, 2008
    could you please tell me how can i activate the the option so that ishould be able to see the drum status,
    Sniper:
  • 57 Answers
Most probably you have a worn out drum, and most probably is the yellow drum. The other possible thing a worn out transfer cleaning blade. I suggest that from service mode and option you activate the drum life display. So that when you press on system monitor and then consumables you can view the all the drums status apart from th etoner availabilty.
Posted on Dec 25, 2008
  • iblah Jan 30, 2009
    Check about the drums status. You can do that from system monitor and consumables.
    If it is not shown. Only toner status shown, you have to activate from service mode.
    Enter service mode, press on copier, option, body, and there you should see one of the settings reads out DRM LFE.... select it, press one on the keyboard and then ok.
    Exit service mode and check from system status...
    One thing should be done as well is from * on keyboard and adjustments and settings run a full auto gradation adjustment.. Good luck.
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
I am getting yellowish in prints
I cause by dirty primary charge roller in yellow drum unit, Replace yellow Drum unit
Mar 31, 2009 | Canon imageRUNNER C3200 Copier
ok if you are getting peices of rubber on the pabe it could be the fuser rollers.. this unit comes out easy.. looking at the unit there are 2 screws on both ends looking back at you... remove the screws and the unit lifts strait up once its out you can see the rollers much better. it is either comming apart or the teflon could be sliding off. if it looks ok you may need to run the paper thru slower it may not be fusing good 2 ways to do it try the bypass and select heavy 1 or you can set the cassette for heavy under add func common settings paper settings...
Dec 30, 2008 | Canon CLC 1180 Copier
Color is bad on the photo
Do a printer utility deep clean
Nov 21, 2008 | HP Photosmart 8450 InkJet Printer
Sanyo 5.0 megpi( yellow tint)
yellowish color is due to the light your flash gives when taking pictures. i suggest you bring that to a service center and let them take a look at your camera...probably needs a bulb replacement.
Jan 26, 2008 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
LCD display has a yellowish tint
This is a defective CCD problem known to Sony. They will replace it free of charge and even pay for the shipping. For more details go here for the link: http://www.imaging-resource.com/badccds.html
Dec 04, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Canon imageRUNNER C3200 Copier Logo
103 people viewed this question
old marine
old marine
