Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
TV goes on and off, no picture.
Currently the TV will not turn on. It tries to turn on then turns off, It continues to make the beeps for turning on, then no picture and it turns off. It keeps trying to turn on, so I unplugged the TV. I thought maybe it would reset. Any help would be greatly appreciated.
4 Suggested Answers
  • 16 Answers
SOURCE: timer continuously won't turn on
Most times the flashing red light indicates the tv is in protection mode due to a problem with a circuit board....Good Luck
Posted on Oct 01, 2007
  • 3 Answers
Can you add more detail to what's happening? Are there any sound coming from behind the set? Do the lights in your home dim as it is cycling on and off? Is there a squealing from behind/inside the set? Was there any repairs or problems prior to this? I ask these questions because I have the same set, and experienced the same trouble. Eventually the cycling stopped and the set began to come on. Then it would start cycling again. Finally the cycling stopped the set came back on, but now the sound doesn't work. I can only hear the sound using my surround system. I currently have parts on order and I'll keep you posted on the out come. My email is for you or anyone else who can shed light on our problem here. If your set is making the squealing sound like a mouse during the cycling process. I believe it is coming from one or both of the large 2200 micro farad capicitors located on the the right power board. They are the largest ones on the board. DO NOT TOUCH THIS AREA UNTIL THE CAPICITORS HAVE BEEN DISCHARGED!!!! THEY CAN KILL!!!! There is also a small black relay clicking on the center convergence board. My problem started about 2 months after I made a repair to the convergence board-swapping out the 2 convergence ICs STK392-040 as well as the blown pico fuses. The convergence seemed to work fine, All color was back to normal after performing the convergence a couple times, but after 2 months this cycling problem started. Any help will be greatly appreciated from anyone. I will keep you posted on my progress.
Posted on Oct 19, 2007
  • 4402 Answers
SOURCE: Akaia PTH5498
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Posted on Dec 18, 2007
SOURCE: TV will not turn on...
I will try anything at this point! I will keep you posted onthe repair. Thank you so much for your assistance.
Posted on Dec 21, 2007
0 characters
1 Points
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
Picture goes diagonal
U know how to solders?Ur convergence it dead,must replaced.Tries these websites for convergence kit.Tv repair,Tv repair kits.
Nov 13, 2009 | Toshiba 50HM66 52" Television
No picture
Sounds like the bulb or lamp needs replaced.
Jul 08, 2009 | Projection Televisions
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
Jul 07, 2009 | Projection Televisions
My Samsung HD TV 50" progressive Monitor goes off and turns dark
Samsung HDTV will stay on when turned on the temp lamp and timer light are flashing continually. what should I do to eliminate this problem?
Dec 08, 2008 | Projection Televisions
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Akai Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Akai Projection Television Expert? Answer questions, earn points and help others
