Panasonic DMR-E50 DVD Recorder Logo
Bob Goetz Posted on Apr 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing Channels I recently had to change from cable service to a satellite system. The problem is that the stations that are on the DVD recorder are not the same as the stations on the satellite dish network. I have got in touch with the dish network people but they have not given me any soultion to this problem. Is there any way the recorder can be adjusted so I can get the same stations that my dish network has?
Anonymous
Level 2:
Scholar:
  • Expert 135 Answers
  • Posted on Apr 14, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
135
Questions
0
Helped
75788
Points
321
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 • Televison & Video
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
2answers
How do I , or in fact can I, tune the DVD recorder such that it can see the digital TV stations - all I get at the moment is analogue channels
can you receive digital channels through your tv (if it is a DAB TV)? The reason i ask is that you may not have a strong enough signal to receive digital channels. Try taking the dvd recorder to a friends house and plug it in there to see if it will tunethe stations in. IF it does try it back at yoursto see if it will pick up the channels if it breaks up the picture then you need to upgrade your ariel
1helpful
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Sony vx 535 will not record dvd from direct tv channels. It shows that it is recording except on playback it is all black.
if your using a cable or satelite box it will work but has to be on the channel and powered on. dont change stations or it will record you changing the stations
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
1helpful
3answers
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
2answers
No audio on tv channels but perfect on DVD playback etc
this looks very much like a problem I once 've had (and later found the solution by accident). When you go into the menu of the remote control and press the "automatic channel search" function you can always specify from which "source" the signal is arriving either 1, from antenna, (ie. over air) or 2, from cable or 3, from satellite. Then the decoder searches and finds a bunch of station in its reach. Once (while hooked up to an antenna) ,I had accidentally made it do the station search under the "cable" header instead of "antenna" and it found the same stations as the one's I've had before,(over antenna) but some stations suddenly had no more audio. Because I was unaware that the set was programmed under the cable header I could solve this strange mystery only much later when I reprogrammed it one day and it searched the stations under the Air-Antenna header, then suddenly all the stations were coming in properly, with good image and full audio. ------If this doesn't solve your problem then search under the menu of your set if at another part of it you can specify some other similar options like Antenna-Cable choice. I'm quite sure its easy to correct. good luck Alex
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
