Question about Dell 924 All-in-One InkJet Printer
Paper will not feed all the through the printer
The paper will start to feed but will not go through as the printer goes through the print cycle
  • Anonymous Dec 30, 2008
    I have the same problem. Paper feeds for about l/4 of a page and then jams. Help!
  • sweetnsexytj
    sweetnsexytj Oct 28, 2013
    i had the same problem with my HP desk jet 3050 all in one. After three days of trying to shake and make sure nothing was in the printer, on the third day i decided to try the suggestion made by cabrooks jr to clean the rollers with isopropyl alcohol to give them their grip back and that is exactly what the problem was..Thanks i did not want to have to buy another printer.
I had the same problem with my Dell 924 and after EXTENSIVE research I found a forum where about 90 percent of the people with the same problem ultimately found some sort of foreign object in the printer. I spent about 30 minutes shaking my printer to no avail then I broke out the flashlight and started looking in every nook and cranny. I lifted up on of the small black plates on the roller towards the back of the printer (if you're looking in the front) and low and behold I saw something that looked odd. Grabbed some tweezers and fished out an allergy pill in a little bubble pack. Was wedged in there to good to fall out from the shaking. Take a piece of card stock or photo paper and try to feed it through the printer manually. If starting at the top, take note of where the paper stops and that should be where your problem is. Try feeding from the top and the bottom, if the paper will not feed through, something is in it's way. Hope this helps.
Posted on Jan 02, 2009
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
SOURCE: PRINTING PROBLEMS
i have had so much trouble with the epson stylis photo r1800... it doesn't feed right every so often and it is so frustrating. It seems to be with the rollers that pull the paper in, I don't think the rollers are pulling at the same strength and causes the paper to feed a bit off and the printer thinks that the paper is loaded incorrectly. Has this happened to anyone else and what can I do to make it work properly. This is also my third printer, Epson keeps sending me new ones when I conplain because they can't seem to help me...
Posted on Dec 18, 2007
  • 171 Answers
SOURCE: HP 1020 Issue
Pls check the fusing assembly,something might be stuck or the flag of paper jam sensor might be broken or could have come off.
Happy printing
OMNIPRESENT
Posted on Oct 17, 2007
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
remove slowly.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
No paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Feb 20, 2009 | Brother MFC-440CN InkJet Printer
My paper goes to one side when printing starts and it does not print ny work
There may be a scrap of paper stuck in the machine, interfering with normal paper feed. Turn off the printer, and try to force a sheet of paper through the printer by hand. Feed the paper only in the normal direction that the paper goes. Forcing it by hand may push out the stuck scrap. Thin cardstock can be used instead of paper.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Jul 23, 2008 | Lexmark X85 All-In-One InkJet Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Paper not feeding into the printer properly
This is usually caused by the pickup rollers. When they get worn just a little they will start doing this. You can try cleaning them with alcohol, this helps sometimes.
Mar 21, 2007 | HP DeskJet 450wbt InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
332 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
