Question about Toshiba Satellite A105 Notebook
Toshiba A105-S101 freezes at start up!
I have a Toshiba A105. When I turn the computer on, the computer powers up, fans come on, DVD drive reads, then it freezes, before the red Toshiba logo comes on. The only way to get it to boot up is to hold the power button in, and repeate the process, untill it boots all the way to the red logo, then on to windows. This might take 40 to 50 times, but it will eventually boot, and work fine. I took it to a shop, and they blew me off, and said the mother board was shot. I don't understand, that it's shot, when it works fine, after you get it to boot all the way. Any help would be great! Thanks...
  • SRabatin398 Jan 06, 2009
    Thanks Smithbrother,
    I already reinstalled the software from my cd, and I have the newest Bios upgrade from the Toshiba page, and I still have the same problem. I wonder if thr chip that the bios is saved on could be bad? I wouldn't know how to change that anyway. Like I said, If I keep powering on and off, it will finally boot, and work fine.
    President:
  • 2,692 Answers
I would first attempt to reinstall the software from the install cd. Your Toshiba support page is recomending a new BIOS upgrade. See below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209144&rpn=PSAA2U&modelFilter=A105-S101&selCategory=3&selFamily=1073768663&selModel=1209144|PSAA2U
Posted on Jan 04, 2009
I have a Toshiba Satellite A105-S101 it was working well then it was left idle for one month then when i tried to update the screen went Blank/black screen, switch is on, no bios set up, no avg out,...
Dead PC
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Hope that helps.
Feb 04, 2011 | Toshiba Satellite A105 Notebook
Toshiba A105-S101 No Video
One of the easiest ways to troubleshoot the no video issue is to get an external monitor and attach a vga cable to your laptop. If there is no problem with the video chip on the motherboard, the laptop will switch display to the external, if it does this and you have a picture, then your graphics chip is good and you may have just lost the screen and /or the inverter powering the backlight. If you do not get a picture OR if you do not see any activity with the hard drive activity led, then most likely you are having a motherboard failure in which your options are repair or replace.
Jan 21, 2010 | Computers & Internet
My laptop(Toshiba Satellite A105 - S2051) wont turn on with or without battery on a/c adapter. Adapter seems to have a charge but when i plug it in and try hitting the power button nothing happens. I do...
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Aug 08, 2009 | Toshiba Satellite A105 Notebook
DVD RAM not reading the DVD on a Toshiba Satellite A105 laptop
did you try to insert other DVDs? if it works then the DVD that you are trying to play is faulty. But if all CDs cannot be read i suspected it's a dvd-rom drive faulty. you need to replace it.
May 28, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-s101 video problems
Unmountable boot volume means most likely the hard drive has failed.
Dec 18, 2008 | Toshiba Satellite A105 Notebook
Toshiba satelite A105?
Hi Koreasp,
You will need to find out the model number aswell, ie "A105-S101".
Once you have that, head along to the Toshiba website here : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#. Click on the download menu at the top. Select 'Portables' in the first list, then 'Satellite' in the second list, then your model number in the right hand list. Then click GO.
On the resulting page, click on 'Users Guide' in the submenu. Or the 'Detailed Specs'.
Hope this helps!
David
Nov 16, 2008 | Toshiba Satellite A105 Notebook
DVD Burner will not burn
Read the front of your drive to see if you have a DVD-R or DVD-RW drive. A DVD-R will copy a DVD to your hard drive, but will not burn it. If you do have a DVD-RW drive, try a different brand of disc or a DVD-R disc, some drive are just temperamental.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
TOSHIBA SATELLIT A105-S4244
Does it show up in xp as being there? Will it spin up when disk is put in? Is it both dvds and cds it wont read?
Jan 06, 2008 | Toshiba Satellite A105 Notebook
Computer Freezes During Startup (Urgent!)
Try firstly, on start up keep pressing F8 until a menu comes up. Look for the line that reads 'Start windows with last known good configuration', move cursor to it with the up or down keys as your mouse won't work; and press enter. Hopefully your pwill restart and run as normal. If not you may need your Windows cd.
Jan 03, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
318 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
