Question about Savv LM-S6001 Car Monitor
Blue screen no picture
My monitor doesnt work.all its got when i plug it into the dvd is a blue screen,sound works fine.the lead is fine that goes from the dvd to the screen ,i tryed it on a different screen.when its switched on its on av.i havent got a remote for it so im not sure if thats why its not working.do i need one to make it work.
2 Suggested Answers
MrLard
  • 94 Answers
SOURCE: no picture
A blue screen suggests no input signal, or a signal that the electronics in the screen can't handle. I don't think you need the remote, but, it may help. I suggest you try the dvd on a working monitor and check that it's a compatible output. The LM-S6001 is a multi-system monitor both NTSC(US) and PAL(Europe/Aisa). The monitor has a composite video (usually yellow) and RCA(phono) input and DIN, the manufacturer is unclear if both plugs are present. You can assume it's auto-switching, but that may not be the case. More information is needed to fully understand your problem. 1. make/model of DVD. 2. description of external plugs on monitor.
Posted on Apr 24, 2007
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Connecting from laptop to tv wont work now. It was working fine previously
Check the display settings on your laptop to see if the external monitor output is disabled. There is usually a function key on the keyboard with a picture of a monitor on it which can be used to switch between internal & external monitors.
You may also need to try on another monitor/TV or change the HDMI lead.
Sep 27, 2012 | pcb Advent 5711 5431 Laptop M/b U41iix...
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at 1800customersupport.com, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
Blue screen flickers and goes almost completely dark... when i plug into a different monitor, everything on that monitor is clear, so i know the compputer itself is fine. How do I check for a loose
most likely inverter issue, or somewhere in between inverter and LCD, illumination bets thing to do is to take aprt the LCD frame and disconnect and reconnect all wires leading from the inverter. If that doesn't work, the replace the LCD wires and or inverter.
May 20, 2009 | Acer Aspire 5100 Notebook
Philips lcd monitor!!
invest in a better monitor. Philip has never put out a good product.
Nov 14, 2007 | Philips 170B4MG 17" LCD Monitor
MY TV!!
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
Sep 25, 2007 | JVC AV-48WP74 48" Rear Projection...
No picture
Apr 24, 2007 | Savv LM-S6001 Car Monitor
Savv LM-S6001 Car Monitor Logo
Top Savv Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Savv Car Audio and Video Expert? Answer questions, earn points and help others
