Question about Panasonic CT-36HL43 36" TV
Panasonic CT-36SL14J White screen
My tv only shows White screen, I see the menu OSD and the numbers of channel, but no image no audio the screen only white, I followed the sign of video and there comes up to the pin number 13 of the IC MN102H81GTG4 AND the RGB of this IC works, but only it shows the menu OSD and the numbers. Someone can help me. This problem was originated by beam!
  • solver gariz Dec 31, 2008
    in speaker hear ''se se" sound also
My Panasonic CT-36SL145J won't turn on
Posted on Jul 25, 2010
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
Hello - two channels on my Panasonic TV (CT-27E13) have no audio. The rest are fine. Any Ideas? Craig
On the original TV remote press the SAP button on the top right of the remote. Keep tapping until the TV says stereo and this should fix the problem.
Good Luck and please rate this solution....
Jan 08, 2010 | Panasonic Televison & Video
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
Odd problem with Panasonic 27" CT-27SF25W
You might want to replace the vertical output IC. This IC has a heatsink on it. I'm not an expert on this, but that's what I can think of. I don't know where it's located, but you can get the numbers on the ICs and google search them. I do that.
Sep 23, 2008 | Panasonic Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Please Help !!!!!!!!!!!!!!!!!!!
1. hit menu, use right arrow and select 'Audio'.
2. hit menu use down arrow to scroll down and select 'Speakers'
3. hit right arrow to scroll thru options, select 'on'
4. hit menu 3 times to save and exit back to picture
Jul 28, 2008 | Panasonic CT-36D32 36" TV
Tv panasinic
francais je suppose.....lol
ecoute dis moi si ta télé fait au moins du bruit au démarrage style sifflement ou rien.
si rien ne se passe c'est probablement ton alimentation a découpage qui a laché.
soit tu ouvres et ragrde si un fusible interne aurait brulé ou alors direction le réparateur
bonne journée ;)
Mar 31, 2008 | Televison & Video
Closed Captioning no longer works
check for the knub OSD on your remote to press it or at the menu select on screen display on
Apr 20, 2007 | Panasonic CT-27SF25 27" TV
Panasonic CT-36HL43 36" TV Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
