Question about Licensed Disney Hannah Montana Wireless Microphone
I bought a barbie Wireless FM Microfone and I need to find out
The radio station in which the mic works
  • 1 more comment
  • AwolRJ Dec 28, 2008
    same problem i opened it for her and threw away the instructions with the package!
  • batcoyote24 Dec 29, 2008
    I have the same problem but with the Barbie FM Microphone , can´t get it to work. it got new batteries but can´t make it work, what can i do?
  • Anonymous May 03, 2009
    El microfono no consigue la emisora para que se escuche la voz en el radio--
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
caraudioquestion@gmail.com
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
What FM frequency does the radio need to be on to use a wireless Disney Mickey mouse microphone?
Each microphone has a different FM Freq. If you can not find a Freq there is a very small hole in the mic near the Mic switch. You will need a jewlers screwdriver to make a freq. adjustment. Hold down the applause button while very close to your FM radio. Use manual tuning on your FM radio until you hear applause. If there is a local station playing on the Freq you can insert the jewelers screwdriver into the small hole and change the FM Freq for the Mic. You only need to make "fractional adjustments" to change the Freq. setting. Once you make a mic freq. adjustment change the radio freq SLIGHTLY up and down until you hear the applause.
This should get anyone going that is having difficulty with this microphone.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Toys
What is the FM radio frequency to use the Hannah Montana Wireless Microphone?
FM 99.7 works best.... However if you have a local FM station using that freq your out of luck UNLESS your handy with a Jewelers screwdriver. Calling tech support will get you a "sorry" but there is nothing we can do. So if you are one of the unlucky ones with a Local 99.7 FM station here is what you can do.
1) Find a dead spot on the FM radio band either at the very low end or high end of the range. You should hear just fuzz (white noise) on your radio. However, on many newer FM tuners if there is no station broadcast there is nothing but silence.
2) Put batteries in the microphone.
3) Get a really really tiny flat head (Jewelers)screwdriver just like the kind in those eye glass kits they sell at the grocery store.
4) Sit right in front of the radio
5) Insert the screwdriver into the tiny hole in the microphone and tune the microphone until the radio goes quiet (no fuzz sound). Or.... you can keep pressing S to hear a beat and the beat is acutally heard through the speakers.
The hole is located just to the left of the screw that you undid to get at the battery compartment, but it's off center. Inside this hole is a small tuning screw. Slowly, slowly, SLOWLY turn the screw driver until you here a change or interruption in the fuzz sound on the radio speakers. This will indicate you found a compatible frequency. Then even slower - tune back to that "notch" until you hear nothing but silence on the radio. Test it by pressing the applause button "A" or by pressing the mic "M" button and talking.
There are multiple places on the FM dial that will "work" as you tune the little screw but you should have already manually selected where (the FM freq) you want to use your mic.
Once it's working it ain't perfect. I doubt you'd do a serious performance on it, but the kids love it.
The mic quality is not top notch for sure.
Fine tune as necessary....
Kelly
Mar 12, 2010 | Licensed Disney Hannah Montana Wireless...
Station to get signal from FM transmitter
I put the transmitter closer to  the antenna and it periodically worked. So, I don't there is a specific station.
May 18, 2009 | Audio Players & Recorders
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
FM radio tune with fm antenna on a305-s6857
maybe you can find the instructions online, or try google it,if not talk to the store or company you bought it from
Aug 17, 2008 | Computers & Internet
Hannah montana mmicrophone
I found this on Yahoo:
I Have The Directions Here
1. for best proformance please note the following
a. place the FM radio in an area of minimal nosie and interference
b. do not set vol to max
c. has to be within 15 ft
d. hear your own voice, will not be brodcasted over the radio
e. in some areas, all frequencies in 92 to 106 FM range could be occupied by a local radio station. in this rare case, your mic will not be functional
3. move mic close to radio while tuning, tuning into frequnecy may take practice. may need to move your radio dial slowly and sing or talk in to the mic
Buttons on the mic:
A.... Applause
S.... DJ Scracth Efeect
M.... Mic
Source(s): Hanna Montana FM wirless mic instruction manual
Feb 10, 2008 | Audio Players & Recorders
Licensed Disney Hannah Montana Wireless Microphone Logo
957 people viewed this question
Top Licensed Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Licensed Toy Expert? Answer questions, earn points and help others
