Question about Kenwood KVT-512 Car DVD Player
Bypass parking brake for dvd player Kenwood kvt 512
What is the best way to bypass my parking brake so that the dvd player will play movies while the vehicle is out of park?
  • 1 more comment
  • Anonymous Dec 27, 2008
    how do I bypass the e-brake to watch dvds on my Kenwood KVT-512?
  • Anonymous Feb 17, 2009
    i have the same problem
  • vijer Feb 26, 2009
    Connecting the parking brake wire to ground does make the dvd display BUT there is NO AUDIO.  I have tried everything that has been suggested on various blogs but none work.  This is truly a software issue and poor design.  The same is true of connecting a memory card to the USB port. The system displays all the MP3's on the sd card and even plays them, but the AUDIO is muted.
    Problem Solver:
  • 6 Answers
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Posted on Nov 17, 2009
  • 4 Answers
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness. It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on. If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead. Solder all three wires together and you should have sound all the time.
Posted on Jul 16, 2009
    Problem Solver:
  • 5 Answers
I just spliced the parking wire into the positive wire on my cigarette lighter. This provides the voltage tricking the player into thinking that the brake is on. It takes almost no voltage to trick it. Even just licking your fingers and touching the bare part of the wire gives it enough voltage to bypass.
Posted on Dec 29, 2008
You dont have a muted audio problem. Download the firmware update off the kenwood website. also jus connect the parking brake wire to a straight ground. works for me
Posted on Mar 08, 2010
Solution 3 is by far the best, just ground the wire....much easier.
Posted on Feb 12, 2010
Dvd video i can,t see it is a messagees :"parking off"
You need to make sure the parking brake lead is hooked up from the radio to the parking brake, and that the parking brake is engaged.
Feb 06, 2011 | Kenwood KVT-512 Car DVD Player
How to play dvd video when driving my car
Most wiring harnesses have a solid orage wire for illumination of the radio2_bing.gif and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal. Just remember to be safe and pay attention to the road. Oh, and most states have laws governing the use of video playing in plain sight of the driver. BE CAREFUL!
Apr 22, 2010 | Kenwood KVT-512 Car DVD Player
Is the park signal wire supposed to be hooked to the ground side or power side of parking brake switch? I'm trying to install a kvt 512 for a buddy, and the dvd player wont work with out the park signal.
If you want to by-pass the parking brake wire, here's how.
Apr 13, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood kvt-719dvd plays dvd but wont show picture
It is probably that the parking safety wire wasn't hooked up properly, or at all. Most in dash dvd players are equipped with a motion safety device to prohibit the driver from viewing movies and such on the monitor while the vehicle is in motion. The wire for this needs to be hooked to the parking brake light wiring. This will ensure that when the parking brake is on, the dvd can sense that the vehicle is stopped, and should therefore show the image.
Mar 15, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
How to play dvd?
ground the parking brake wire
Feb 07, 2010 | Kenwood KVT-512 Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
Apr 09, 2009 | Kenwood DDX-512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
run a jumper to GROUND from that lead. it must remain shorted all the time you intend on watching the dvd player. With that said, I have one in my car that is hooked up that way and I put mine on a toggle switch so that, in the event I get pulled over I can hit the switch and it won't work unless I pull the brake. If you get caught wacthing a movie while moving, there is a fine associated with it! just letting you know. but its very kool to have it on long trips.
Mar 03, 2009 | Kenwood KVT-512 Car DVD Player
Brake Bypass Code
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
Sep 28, 2008 | Kenwood KVT-512 Car DVD Player
Kenwood kvt 729dvd
connect the green wire from head unit to ground perminetly
Feb 02, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-512 Car DVD Player Logo
5,305 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
