Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton not working
I have the GE Triton dishwasher and all of a sudden the lights are malfunctioning on the panel and it won't start.  Has anyone else had this problem?
  • 2 more comments
  • TootieC Dec 28, 2008
    Yes, I have the same problem. Working fine until Dec. 29th and suddenly panel lights have gone wacky and it will not start a cycle. Is getting electricity ok because panel lights are on. GE Triton Quiet Power III.
    Can anyone help us?
  • Donald Marshall Feb 03, 2013
    YES cutting the power for five minutes worked, Now my wife can get off my back for not getting and extended warrantyt.y
    Yes it works. Cut the power for a couple of minutes and it starts.
    Now my wife can get off my back for not getting an extended warranty.
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Posted on Dec 29, 2008
I had same problem....turned off power breaker for 5 minutes and when I turned it back on lights were fine and dishwasher works fine.
Posted on Apr 22, 2009
  • 3 Answers
If none of the previous solutions work, consider checking the wiring at your power junction box located at the bottom of your dishwasher. It should be located just behind the toe plate which is just below the dishwasher door. Be sure to disconnect the power at the wall or circuit breaker before removing the junction box cover and checking the wiring.
Good luck
Posted on Jul 12, 2010
During a thunderstorm, I noticed that several lights that shouldn't be on were on. Later, all lights were off and the dishwasher wouldn't start. I turned the breaker off for a minute and then back on. The dishwasher pump was running then. It wouldn't respond to the reset/run button but started a new cycle just fine when I touched "normal wash." Turning the breaker off and on is definitely the first thing I recommend trying.
Posted on Aug 01, 2009
I have a GE Triton XL dishwasher. The power went out during the night, and when it came on the dishwasher was making a loud alarm sound and the control panel isn't working (no lights or anyth
Yes, try unplugging it (or turning off the circuit breaker), wait for 15 to 30 seconds and then try pluggin it back in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 11, 2014 | GE Dishwashers
Water does not pump into dishwasher from line, tho
the start buttom lights geen for 7 times , may be from the lack of water , but the water supply was solved & the dishwasher didnt start again !!!
Feb 01, 2010 | GE Dishwashers
The control panel of our GE Triton is not working. Is there a reset button?
Triton is usually trouble-free, however there is no reset button. Depending on the model and series, there may be a code (that is: a combination of panel buttons to push that will bring the control to a zero entry level (also known as default level). This would be in the owners manual under trouble shooting or problem with the appliance.
The other option that works many times is: disconnect power to the unit for 2 minutes. This will help the control to start its logic from the beginning. Then turn power on and try the machine; this will tell you if the control now responds. IF NOT , you have an 80% chance that a new control panel is needed. Welcome to the wonderful world of electronics. Its great when all is working, but ohhhh so tempermental.
Goodluck, Macgivor
Oct 24, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
I have a GE Profile Triton Dishwasher and it has worked fine for about 8 years. Suddenly it will not reset. The reset light blinks after reset but you can not choose a normal cycle afterwards. I shut of...
Hello, how are you?
It sounds like you have a stuck key on the keypad, preventing you to push any other key.
I've seen this problem many times in the past 4 years.
Good luck.
Ned
Sep 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
MAYTAG MDBH945AWS MODEL WANT START. ONLY START LIGHT IS ON.
stacy314-
I just had a similar problem with a GE Triton. Suddenly the lights on control panel went wacky and it wouldn't start. I don't know if this will help you but try disconnecting the power source and wait a bit (this involved turning off the circuit breaker to d/w in circuit box). It cleared up the problem with the control panel and d/w just finished a good cycle. Hope this helps you. It was Step #1 on another site and they said there that this will allow the "computer" to re-set.
Good luck.
TootieC
Dec 29, 2008 | Maytag 24 in. MDBH950AWS Built-in...
I have a ge triton dishwasher model number gsd556ogo3ss and it continues to make a beeping noise and the sensor light is on
Open the dishwasher
Remove door panel
Look for a switch with 2 spade lugs attached
Make sure the 2 wires are not broken or corroded
Use a tester to verify switch opens and closes.
replace switch and your problem should be solves
Jun 14, 2008 | GE Dishwashers
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton Dishwasher won't stop running
try to reset the circuit braker--remove all power.
Aug 27, 2007 | Dishwashers
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
1,744 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
