Question about Envision E20E221 20 in. EDTV-Ready LCD Television
LCD Monitor w/TV Tuner now flickering on and off when using w/PC
I've had an Envision E20E221 for a couple of years and haven't had any problems until recently when the power started flickering on and off with the PC connection. I do not have this problem when using the TV Tuner, though. I'm perplexed. Any suggestons?
The television connection and the computer connection may run through different parts of the power board, but I the same problem with my LCD Monitor as your having... I pulled it apart, and learned that CapXon Capacitors are garbage... I went to Digi-key.com and ordered 6 capacitors for less than $10... or you can call 1-800 DIGIKEY and thier tech support will walk you through the order. Replacement was simple and clear with a hot soldering iron... And a lot cheaper than $95.00 for a new power board. I had 3 bad 470 25v CapXon capacitors.
Hope this helps!
Posted on Dec 23, 2009
  • hman1169 Jan 18, 2014
    years have passes since the repair and that monitor is still working great. The whole job only took about 30 minutes, the only thing you have to pay attention to is what side of the capacitor is negative. i recommend taking some pictures before you start and change one capacitor at a time.
What could be wrong for my l42w761 to have no picture, and the yellow standby light blinks 20 times?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 27, 2014 | Envision L42w761 /720p
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
When turning on computer screen states no signal, has worked fine for a couple years
Please check all the pins on the video cable and also try it with another PC to make sure it is not PC video card problem. Please post back what you find.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 09, 2010 | Envision EN-7410 17" Flat Panel LCD...
I have bought Envision E20E221 in the USA. But now I have problems with its conection in Ukraine despite this LCD model has SECAM and Pall. I need your suggestion.
Sorry u can't not used this tv,because u bought it in the US.Ukraine in Europe.It used PAL signal frequencies.The US used NTSC signal frequencies.
Oct 21, 2010 | Envision E20E221 20 in. EDTV-Ready LCD...
I have an Envision monitor. For a couple of
jbfrmga1, It's possible that you or a qualified electronics technician will need to open the monitor and inspect the printed circuit boards for the ONE and ONE only "bad and thermally intermittant" solder joint and resolder it. You may need large magnifying glass or low power 8x to 20x inspection microscope to locate the "thermally-fractured" solder joint of an active or passive electronic component that has become intermittant on the "switch-mode-power-supply/ccfl inverter board. To prove problem is inside lcd monitor, move (connect) "cold" monitor to an already fully booted pc with the WIN-desktop screen already displayed on a good monitor. 12fixlouie
May 18, 2010 | ViewSonic VX924 19" LCD Monitor
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
We have an Envision 9410e 19" LCD monitor which is about 4 years old. Recently it has started being very slow to start up, especially in the morning after the system is not in use all night. The screen...
cmgusa, Reconnect 9410e to original PC. Please note if same symptom occurs again. This sounds like an intermittant or failed solder connection of some component on the inverter/smps power supply board. Have you tried the FLASHLIGHT test when the monitor goes to a BLACK screen? You did not state the approx # of hrs of use this unit has on it. The Flashing you describe is most likely the cold-cathode-fluorescent-tubes trying to start-up. If they don't light then you get a black screen. They (CCFT) get their voltage from the inverter section of the power supply. But anyway... Your options as a consumer/user are as follows. Check with Envision to see if they have a swapout program... you send them your 9410e +$50-$90 and they send you a REFURBISHED 9410e with 30-90 day warranty. or Find local TECH (TV-Monitor) who knows forward and backwards all there is to know about repair of LCD monitors. There are some very good tech's right here on fixya that could do the repair and not rip you off. Last but not least is try to effect repair yourself. If this last option is of intrest get back to me only after doing web search of monitor disassembly video clips on youtube and doing search for things like bad caps or recapping and inverter repair + have a minimal understanding of how a SMPS/inverter powersupply functions. I'm louie12fix on fixya or lmistyrel @aol.com Bye for now.
Sep 21, 2009 | Envision 19" Widescreen Flat Panel LCD...
Can't get sound to play on my AOC LCD from my XP computer.
did you have an installation disk?? If so it may not have loaded in the setting to make the sound card accept the monitor..Or simpler--is the right wire plugged into your computer for the sound??
color codes don't always match for generics.
Oct 12, 2008 | AOC A15X221 15 in. LCD Television
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Envision E20E221 20 in. EDTV-Ready LCD Television Logo
178 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
