Question about Mavic Ksyrium Elite Wheelset
Front wheel installation
Is there a "left" side / "right" side on the front wheel due to the design angle of the rim?
  • 18 Answers
The lever on the quick release skewer goes on the non-drive side of the bike.
Posted on Jul 01, 2009
I have Toyota 2006 sienna and front right wheel shakes or wobbles ... I have new front tires and balanced.. but still wobbles a little...please any thoughts?
Hi Scott.
Try switching the wheels from left to right side and see if the wobble goes with it.
If not, look for a worn tie rod end or other suspension component.
If wobble goes to left side, look for bent rim.
Cheers.
Oct 10, 2015 | 2006 Toyota Sienna
Correct wheel placement?
I`ve only seen 2 cars that require the tires to be installed in a particular spot. usually because the tire width was different from front to rear and would not allow the wheel to be turned to full left or right. also some tires are designed to work in a specificate location due to load and traction under certain conditions. these cars are an early Camaros(80s) berlanet and corvettes. so these tires you have were designed and made to work in these spots.
Mar 26, 2015 | Cars & Trucks
After removing the front lug nuts and small center nut , i am not able to remove the wheel and tire
in past experience I've seen the center of the wheel actually rust or just from normal road grime stick to the hub I had to kick the outer edge of the rim if that don't get it loose dictating on the kind of rim you have can use a pies of wood so you don't damage the rim but put the wood against outer edge of rim and hit it with a hammer will have to go back n forth from left to right side of wheel but it will come loose
please keep in mind this only works if all lug nuts are indeed off the center nut you was talking about does not hold the rim in place it hold the axel tight in the hub, which I am assuming you have a front wheel drive vehicle due to your question
Aug 30, 2014 | Cars & Trucks
Front Wheel Allignment
On these LH body cars, camber is not adjustable. Neither is caster. Those angles are preset by the suspension geometry. However, specifications for them ARE published. Generally, if either of those two parameters are out of spec, then it's likely something is worn or damaged and needs to be replaced.
The only adjustable parameters are to the front and rear toe but specified as "Total Toe" - see note below.
The alignment specs are as follows ...
ALIGNMENT SPECIFICATIONS AT VEHICLE CURB HEIGHT
A. FRONT WHEELS
  1. CAMBER
    Acceptable -0.6° to +0.6°
    Preferred +0.0°
    Side to Side Differential
    Acceptable 0.7° or less
    Preferred 0.0°
  2. TOTAL TOE - Specified in degrees. See Note Below
    Acceptable 0.4° in -to- 0.0° out
    Preferred 0.2° in
  3. CASTER* (reference angle)
    Acceptable +2.0° -to- +4.0°
    Preferred +3.0°
    *Side to Side Caster Difference not to exceed
    Acceptable 1.0° or less
    Preferred 0.0°
B. REAR WHEELS
  1. CAMBER
    Acceptable -0.6° -to- +0.4°
    Preferred +0.1°
  2. TOTAL TOE** - Specified in degrees. See Note Below.
    Acceptable 0.2° out -to- 0.4° in
    Preferred -0.1° in
    **TOE OUT when backed onto alignment rack is TOE IN when driving.
  3. THRUST ANGLE
    Acceptable -0.15° -to- +0.15°
Note: "Total Toe" is the arithmetic sum of the left and right Toe settings. Positive is Toe-in. Negative is Toe-out. Total Toe must be equally split between left and right wheels. Left and Right Toe must be equal to within 0.02° (2 one hundredths of a degree).
Courtesy RJK & Concorde Shop Manual
Mar 08, 2014 | 1994 Chrysler Concorde
How to do a wheel alignment
nearly impossible but there are some things that you can do to reduce tyre wear.. 1---place the wheels in the straight ahead position. Using a spirit level place it vertical across the front rims touching only the rim top and bottom . adjust to achieve the bubble just touching on the outer line. That should give you about 1/2 to 1 degree camber. next measure with a tape the distance between the left and right rims 1/2 way up on the front of the rim. Record this measurement. Repeat the measuring at the back of the front rims at the same level as the front measurement was taken Adjust the tie rod ends evenly until the front measurement is anout 1/8 to 1/4 " smaller than the rear measurement. This is the toe in/ out measurement. The caster adjustment you will need a caster angle gauge. They are available and they stick on the hub center. and measure the difference in degrees from full left to full right turn. It need to be about 1 to 1&1/2 degrees positive.. It would be cheaper on the tyres to have the alignment done professionally and a sight quicker.
Apr 04, 2013 | Subaru Impreza Cars & Trucks
THE LEFT SIDE OF THE HANDLE BAR SEEMS TO BE HEAVY THAN THE RIGHT HANDLE BAR.. SO I CAN FEEL THE INBALANCE WHENEVER I RUN THE CB IN THE HIGHWAY...
Lift the bike off the ground (front end), turn steering side to side, should be smooth all the way (not notchy), check your tyres both front and rear, uneven wear, warped rim, should spin freely and true (wheel bearings) than check for fluids on your fork legs, your front fork seals may be leaking or the oil may be due for a change!!
Feb 14, 2011 | Honda Cb 400 F Motorcycles
I got grinding it the front wheel bering,,but only the left
ok you have a bad right front wheel bearing by what you are describing
Sep 04, 2009 | 1997 Ford Aspire
Question on rims on a 1988 IrocZ28. the front rims have a stamp on them indicating 'front' and the back rims 'rear'. the tire size that came on the car when I bought it are P245/50/R16 (96T-mts). Im pretty...
Those wheels are what is referred to as "staggered" meaning different sizes front and rear. If you measure the width of the wheels the rear ones will be wider. I'm not sure what size you are supposed to be using but the rears should be wider. This kind of setup is not designed to be rotated. You could rotate side to side but this won't even your wear out.
Aug 08, 2009 | 1988 Chevrolet Camaro
Mavic Ksyrium Elite Wheelset Logo
191 people viewed this question
Top Mavic Cycling Experts
Michial Gueffroy
vidiot1961
Level 1 Expert
Paul Bade
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
