Question about Jenn-Air JED8430 Electric Cooktop
Wiring installation I am installing a downdraft cooktop, which has four wires connecting to the cooktop. The wires are green, red, black and white. The cooktop is 120/208V. The wiring from the breaker box is 120V and has black, white, and ground wires. I assume when connecting the wires that the green is connected to the ground, the white wires are connected to each other, and the black wires are connected to each other. If that is correct, where is the red wire connected to. Is it connected to the white or black wire? Thanks.
  • 3 more comments
  • Anonymous Nov 16, 2007
    I havethe same problem. My cooktop has four wires, White, Black, Red, Green. My service is white, black and bare (ground). Do both the black and red from the cooktop go to the black from the service?
  • kobosko May 25, 2008
    same problem as above. I have insulated the red wire (not connected to anything). Should I connect the red to the other blacks?
  • Anonymous Mar 29, 2009
    exactly the same
  • wcapate Apr 20, 2009
    the cooktop has red,black,white, and green wires--the supplu is white,black, and bare copper-how do they connect?
  • Anonymous Mar 24, 2014
    we need to rewire the cooktop have wiring just dont know how to put the wires back
This answer does not solve the question regarding what to do with the red wire??
Posted on Jun 18, 2008
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Posted on Apr 16, 2007
2 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Fixing wiring
yes, that is the correct wiring
Feb 08, 2009 | Jenn-Air JED8430 Electric Cooktop
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Nov 07, 2008 | Cooktops
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
On Cooktop From Box
Black to Black
White to Ground
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
944 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
