Question about Seagate Barracuda 7200.10 - 250GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6), 1030Mbps, 72... 250 GB EIDE Hard Drive
Problems with Seagate Barracuda 7200.10 - 250GB SATA HDD. Spins up then spins down and parks. Not detected in OS.
5 Suggested Answers
rajeshmb
  • 38 Answers
SOURCE: i have a problem .i.e
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
Posted on Nov 14, 2008
  • 120 Answers
SOURCE: Hi I am facing a problem Seagate SATA HDD, like when i am going to install the OS it will no install its showing a blank screen, HDD was detecting BISO & also when i connected to secondary devic
You're probably going to have to go back to the machine that it came out of to boot it. Unless you can boot as a primary (it was the boot drive?) in safe mode.
Posted on Jul 08, 2009
ajitvd
  • 89 Answers
SOURCE: Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Posted on Aug 22, 2009
  • 37 Answers
SOURCE: Seagate Barracuda 7200.10 250mb HDD - Spins up then spins down
When a seagate spins up, and then you hear it clicking for awhile, and then finally spins back down - indicates it's got a bad head.
If you can find a donor drive, and can get your hands on a head removal tool, you can swap the head assm long (assuming you can keep things clean enough) enough to retrieve your data.
Posted on Apr 19, 2013
I have 250GB segate internal hard disk but framework is corrupt how i upgrade or recover my date (Disk not detected)
if its not detected this solution maybe crazy but sometimes it will work.. cover the hdd with polythene (air tight) and keep the hdd inside the refrigerator - freezer for 4 - 6 hours and try to connect as secondary hdd (not master) in linux os installed computer and try to recover the files.
Aug 16, 2013 | Seagate Barracuda 7200.12 250GB Hard Drive...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
I have Seagate HD 500GB (Internal) and my PC configuration is Intel i3 Processor with 2GB RAM, 1GB Nvidia Graphic Card and 250GB HD(Internal) in which OS is loaded. I'm facing a problems as...
Your problem is very clear... The HDD has got bad sectors in it and that is the cause for the Sneak sneak sound...
This causes your HDD to not get detected under bios in most of the situation and this is the root cause for all the problems stated above...
Here is the solution:
It is not possible to do any kind of service from your end...
It has to be sent to a seagate service center to get serviced...
Mostly they will never service the HDD, they will replace it with a new one...
All the seagate HDD comes with 5 years warranty...
you can opt for replacement...
search in google for an authorised service center located in your locality...
Dec 18, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I try to install any os to this seagate barraguda 7200rpm, 80 gb hdd don't have completed installtion successfully. many files are missed. some times do not detecting the hard drive.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 30, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
7200.10 500GB Video Included. Humming, Wobbling, Beeping Sounds
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware/ follow indications carefully
Jun 25, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Dec 25, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 - 250GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6), 1030Mbps, 72... 250 GB EIDE Hard Drive Logo
225 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
