Question about Envision E20E221 20 in. EDTV-Ready LCD Television
Lcd tv my screen keeps flickering but its not from the coaxel cable I've had the Envision E20E221 (20") for a couple of years now and it has been working well until recently. I am currently having problems with the LCD flickering on and off only when I'm using it with my PC. When I use the TV Tuner (I have a cable connection), there is no problem. Does anyone have the solution to this problem?
  • Envision Master
  • 13,433 Answers
Can you try the tv with another computer, also you could try another cable.
I suspect your tv is fine theres a problem with the cable of the computer settings. try another computer and see if it flickers.
Posted on Dec 25, 2008
I have thin vertical lines
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Samsung 50 in. Plasma TV
What could be wrong for my l42w761 to have no picture, and the yellow standby light blinks 20 times?
- Flickering screen
- Dim screen
- Slow start
Aug 27, 2014 | Envision L42w761 /720p
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
Dec 12, 2012 | AOC Envision L32W461 32 in. LCD HDTV
When turning on computer screen states no signal, has worked fine for a couple years
Please check all the pins on the video cable and also try it with another PC to make sure it is not PC video card problem. Please post back what you find.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 09, 2010 | Envision EN-7410 17" Flat Panel LCD...
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
LCD Monitor w/TV Tuner now flickering on and off when using w/PC
The television connection and the computer connection may run through different parts of the power board, but I the same problem with my LCD Monitor as your having... I pulled it apart, and learned that CapXon Capacitors are garbage... I went to Digi-key.com and ordered 6 capacitors for less than $10... or you can call 1-800 DIGIKEY and thier tech support will walk you through the order. Replacement was simple and clear with a hot soldering iron... And a lot cheaper than $95.00 for a new power board. I had 3 bad 470 25v CapXon capacitors.
Hope this helps!
Dec 25, 2008 | Envision E20E221 20 in. EDTV-Ready LCD...
Lcd tv
MY TV KEEPS FLICKERING LOOKS LIKE IT IS FAST FORWARDING. IT SOMETIMES LAST A LONG TIME ,OTHER TIMES NOT SO LONG BUT IT IS VERY ANNOYING. IS IT THE TV OR THE CABLE BOX? PLEASE ADVISE. I HAVE VERIZON CABLTV WITH FIOS...........THANK YOU VIRGINIA KIRLIS
Jun 22, 2008 | Televison & Video
Envision E20E221 20 in. EDTV-Ready LCD Television Logo
52 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
