Question about Whirlpool GGQ8831L Gas Dryer
My whirlpool gas dryer is not heating. The flame keeps going out within minutes. There is no blockage.
  • xxpaulb Dec 26, 2008
    I have the same issue. I have already replaced the coils and it stops heating after a minute or two on the highest setting. No blockage either.
  • scg1561 Jan 03, 2009
    The Model Number for our dryer is LGR8648LW0. The flame will come on after a few minutes - heat the air going to the dryer and after a minute or two the flame will shut off and not come on again. There is an ispection port on the front of the dryer and I can see the glow plug come on but the flame never reignites. If it was the coils, I would think it would not even work the 1st time. The fact that the glow plug comes on makes me think the timers are working correctly. guess I'll try replacing the coils and see what happens
  • 179 Answers
You need to replace the coils
Posted on Dec 26, 2008
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
For whirlpool duet GGW 9250 PW0 GAS DRYER How do you know if the gas solenoid are bad? I check the resistance as per manual and its within its limit. It ignites and flames come out but the flame only...
The gas valve solenoid coils work when cool that's why the resistance reading is within the limit but fail when heated. Bypass the thermostat on the burner funnel and if the flame still goes out too soon, the coils are weak and both must be replaced. The resistance reading is reliable only when the dryer does not heat at all or shall we say the flame does not go on at all and the purpose is to check the continuity of the coil.
Oct 12, 2010 | Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I replaced the fuse and the coils for my Whirlpool dryer because it would heat up and then the flame would go out after it ran for 5 - 10 minutes. Now what could it be? Whirlpool Gas Dryer LGR8648LW0
heatman101
Aug 19, 2010 | Whirlpool Dryers
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Whirlpool GGQ8831L Gas Dryer Logo
223 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
