Can't get airconditioner to work
The green light on airconditioner keeps flashing, the fan can start to work but cannot get cool air. It is a Carrier air con but don't know the model.
  • Anonymous Apr 17, 2009
    I have the same problems... The green light flashes 6 times, pauses and then repeats.
  • Todd Born
    Todd Born May 11, 2010
    thats not much information to go on . like where is the green light at? is it a package termional air conditioner ,split system, window uit, or package unit. Bext what type of heat? Gas ,electric,oil,hydronic, or heat pump
  • 236 Answers
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Posted on Jan 08, 2009
Is there a reset switch on Carrier airconditioner
No turn you termalsate to the off pos. Then to fan on. Them see if it goes off and then switch to cooling on the coldest sting if the fan in air handler shuts off before. The stat tells it to it might be kicking out on thermal overload bad motor. Check the condnsor fan for this to fans don't turn on unless they are told to by power going to a board or a relay low voltage control wires may be damaged clean the units pay a tension
Jul 31, 2016 | Carrier Heating & Cooling
Cool air not coming out if air conditioner but all else works. Fan on outside equip works , air through ducts. Thermometer temp stays same. Water comes out of drip pipes .
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 05, 2011 | Carrier Heating & Cooling
Carrier 38CKC060370 The fan seems to work but air is not cold.
heatman101
Jul 03, 2011 | Carrier 38CKC060 Air Conditioner
The heat pump and fan stoped working the thermastat red light is flashing a code 2 blower fan and emergency heat working in the house.
heatman101
Mar 20, 2011 | Heating & Cooling
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Cools for a while ... keeps running but stops cooling.
If the refrigerant has been accurately charged and diagnosed, I would look for an air restriction. Check your filter first of all. It sounds like it may still be trying to freeze up. Make sure all the vents are at least a little open and the return grill is not blocked. In the Rocky mountain region we like to see around 44- 50 deg. at the vents. 65 would tell us that everything is not ok.
Jun 16, 2008 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
696 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
