Shop changed fuel pump and there has been a problem every since. i tried changing batt in key. tapped key in ignition a few times. makes clicking sounds but i noticed the auto steering wheel adjustment doesnt activate, no ding ding noise, no lights on dash when key is inserted. checked fuse 25. 18 isnt in the box. THIS RR IS DRIVING ME TO DRINKING ESP IF IT COULD GET ME TO A STORE. PLEASE HELP. PLEASE
SOURCE: 1998 land rover discovery won't start
I just expiriance the same problems on my rover so i check it out and found that the engine spark fuse was out. I replaced the said fuse and their you go it started. You can find that fuse under the dashboard in the satellite 1 fuse box. it should be the 3rd one from the right. Good luck buddy hope that helps you out.
SOURCE: Tappets making a constant noise
i would suggest asking your mechanic which viscosity(thickness) oil he put back in and check it against the manufacturers recommendation as if it isto thin then it will make your tappets unusally noisey if he has put in the correct oil then i would say that they were quiet because of the old gungy oil and they either need adjusting or if they are hydraulic then the lifters need replacing
SOURCE: defender 90 power steering box
Ther is an adjustment on the steering link between the drop arm ball joint and the oppositi wheel . Loosen the clamps and turn the shaft with a pipe wrench while noting the steering position.
SOURCE: Steering Vibration (Death Wobble)
HEY I HAVE A QUESTION YOU DONT FEEL THE PROBLEM WHEN YOU HIT THE BRAKES AT HIGH SPEED IF YOU DO THE PROBLEM IN WHIT YOU BRAKES YOU NEED TO DO NEW SURFACE IN YOU ROTORS AND PUT NEW BRAKES
SOURCE: my 197 range rover wont start -replaced fuse box
hi i have a range rover p38 2.5 diesel it starts but wont drive when you put in drive
