Question about Electronics - Others
Started to play vhs tapes from 12-15 yrs ago.. first one was perfect second one woudln't play, seemed stuck...tried to gently manually wind or unwind it and it wouldn't move.. HELP.. can a professional place put this on a dvd for me?
  • 69 Answers
I pro can probably put it on a dvd for you, the problem is video tapes degrade over time. you may end up paying his labor with little to show for it. check first and see if they offer any type of refund if nothing is worth transfering
Posted on Dec 25, 2008
I start to play a VCR tape and it just stops playing and the machine turns off. This doesn't happen with a DVD, however.
The VCR tape will turn off when spools are Jammed to prevent breakage of the tape. Take out the VCR cassette and put a thick pencil in the each sprocket hole and try winding in the right direction (which means when you manually wind the tape the other spool should unwind without resistance). If you feel resistance the sprockets are jamming. Knock the cassette on a hard surface without breaking it and usually it will free the jam. If does not help then carefully open the the cassette screw and re-position the sprockets.
Mar 29, 2015 | Televison & Video
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
How do I release a tap stuck part way in the U760??
i had this model once upon a time. the only way i can think of is to try a mini screwdriver to push in the tab on the vhs tape. maybe then it will move. i had to have mine repaired when my aunt did it to mine, 20 yrs ago.
Sep 22, 2014 | Mitsubishi HS-U760 S-VHS VCR
Panasonic VHS PlayPak tape is stuck inside
I've only seen one of these, but I seem to remember there was a manual release that would let you unwind and open it. I cant find any documentation for this thing online or I might be of more help.
Apr 13, 2014 | Panasonic Playpak Vymw0009 Tape Adapter
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Tape won't play
I am assuming that the problem is with just the one tape...
Two things spring to mind - Either the tape has snapped or the reel lock mechanism is jammed.
1) Check the tape. With the cassette the right way up, press the little button on the right-hand end just behind the tape flap, flip the tape flap up and check that there is actually some tape there. If not, it's snapped.
2) With the cassette upside-down and with the tape flap facing away from you, you should see a small hole in the centre of the cassette about 2cm from the edge nearest you. Press something gently in here to release the reel locks. Then give both reels a couple of small turns back and forth (a finger stuck in the reel holes is ideal for this!) Before you put the cassette back into your machine, make sure there isn't any slack on the tape by gently winding any excess back in by turning the reels, but don't wind it to tightly - the moment you feel resistance, stop.
Hope this helps,
Matt
Mar 22, 2008 | JVC DF420 D-VHS Tape
Tracking problem
Suggestions: 1. Do a "reset" by unplugging VCR for 30 seconds or so. Doubtful to fix- but worth a try. 2. Pull the top cover, load a tape and play. Does the tape seem to wander up and down across the video or control heads? If so, this is a mechanical problem- perhaps a tape guide is broken. 3. Electronic problem: If this is the case, probably trash the unit unless unit is a high dollar ($250 or up). VCRs (like most other consumer electronics) are throw away items these days.
Feb 18, 2007 | Samsung SV5000W VHS VCR
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
