Question about Schoenhut Toy Drum Set
Bridgecraft DeRosa 3 piece drum set-
The instructions were not included. I need help asap
  • 13,433 Answers
Assembly instructions are included in the box and vintage will email them to you as well.
here is the contact details page http://www.vintagedrum.com/contact.htm
Also vintagedrum company president and drummer, Ned Ingberman, is ready to assist you by phone. Just call 800-729-3111, Mon- Fri, 9-5 pm CT.
Posted on Dec 25, 2008
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
How many place settings should I buy? How do you decide this?
It starts from 3, 4, or 5 piece sets. lids and saucers are separate. 3 piece set will have a plate, cup, and saucer. 4 piece includes a salad plate and 5 pieces also include either a bread and butter plate or a soup bowl.
english dinnerware will usually have 7 pieces: dinner plate, salad plate, bread and butter plate, cup, saucer, soup bowl and stand.
The number of setting you buy depends on the number of people in your family or the number of people you plan to have in your family in the future. It also depends on how much entertaining you do.
May 06, 2013 | Home
We have misplaced the instructions to convert our storkcraft aspen crib to a toddler bed
Call Storkcraft and ask if they can email instructions. Explain that their site isnt working
and you need them asap. Should do the trick.
Contact Stork Craft toll-free at (866) 361-3321
Storkcraft Website
Good luck
Apr 18, 2011 | Storkcraft Baby Aspen - 4 Piece Nursery...
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Need assembly instructions for baby bed model #012614
I need instructions to asseble jenny lind crib #012614
Sep 05, 2008 | Evenflo Jenny Lind Crib
Schoenhut Toy Drum Set Logo
217 people viewed this question
Top Schoenhut Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Schoenhut Toy Expert? Answer questions, earn points and help others
