Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
My canon powershot sd1000 has a "lens error, retart camera" when I turn it on.. then it beeps a few times and turns off. Is it worth sending it somewhere to get fixed or would be just be more cost effective to get a new one?
  • NoemiZevallo Dec 28, 2008
    RESTART
  • Anonymous Jan 01, 2009
    where is the restart button
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SOURCE: Problem with canon powershot SD1000
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty , or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these Canon repair instructions useful and have managed to solve the E18 problem, write us about how you did it. We're looking forward to your emails. Also, please use the links bellow to bookmark us on Del.icio.us and Furl.
Bookmark This Page on: Del.Icio.Us / Furl
Posted on Feb 29, 2008
SOURCE: Powershot SD1000 as webcam
I tired to do this with my SD600 and could not figure it out but I think it is possible with some changes to the camera like this
http://lifehacker.com/387380/turn-your-point+and+shoot-into-a-super+camera
anyway I have not tried it because they don't support the sd600 so I have no idea if this is safe or works.
Posted on Aug 11, 2008
SOURCE: lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
Posted on May 16, 2009
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 30, 2009
  • 11967 Answers
SOURCE: lens error-restart camera on my canon power shot sd1000
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Dec 26, 2009
I have a Canon PowerShot SD1000. When I try to turn the camera on it says " Lens error, restart camera". Can I fix this on my own or does it need to be taken to a shop?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 13, 2011 | Canon PowerShot SD1000 Digital Camera
Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
Lens won't close
Apr 17, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
http://e18.bitnet.cx/comments.php?full=1
Aug 18, 2008 | Canon PowerShot SD1000 Digital Camera
Powershotsd1000 problem
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 19, 2008 | Canon PowerShot SD1000 Digital Camera
Powershot A560
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 15, 2008 | Canon PowerShot A560 Digital Camera
A460 lens error, restart camera
Jan 02, 2008 | Canon PowerShot A460 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
