Question about Emerson SpongeBob SquarePants TV
Spongebob DVD player has key lock on. Remote doesn't work.
The key lock is on and the remote isn't working in order to turn the keylock off. Is there another way to remove the keylock. The DVD player can't play any movies because you can't press play. Thanks
  • 2 more comments
  • tsharris Jan 06, 2009
    I am unable to unlock the keylock
  • melissa_oval Jan 22, 2009
    I have the same problem. there is some lock on the tv and it won't even play G rated movies. I don't know who to contact for the pass code.
  • Anonymous Jan 26, 2009
  • Anonymous Feb 22, 2009
    Key lock on and can't run the movie...what the heck?
5 Suggested Answers
  • 979 Answers
SOURCE: spongebob remote
Contact Emerson Electronics customer service to acquire a replacement remote for this set, as this set does not have the extensive circuitry inside to duplicate the functions of said remote...accordianman
Posted on Oct 20, 2007
ctf1800
  • 4402 Answers
SOURCE: Need a new remote for my SB315.
just get a generic remote and any tv shop
Posted on Dec 03, 2007
ebrus
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
e-Guru
  • 3917 Answers
SOURCE: I have a spongebob TV
Please contact Fox-International.com for replacement remote. it's where I got mine or
just get a generic remote and any tv shop .
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one that they provide you when you get digial service.
The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
Thanks for contacting Fixya.
Posted on Jul 01, 2009
Keylock no remote
Hello
It will be very difficult to get the set out of keylock, without its original remote control.
Jan 02, 2012 | Emerson Dora The Explorer DVD Player
Is it true that the spongebob tv/dvd only works w/remote control?
Yes,the universal remote don't work with this tv,because it special make for Disney,by a small company.Try website like Remotes.com to buy an exact remote to the orignal.
Sep 09, 2010 | Emerson SpongeBob SquarePants TV
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I have a Spongebob tv/dvd player. When trying to
I looked through the manual and didn't see anything either. I assume that you are hitting the TV/DVD button and setting it to DVD when you want to use the DVD. Does the remote do anything besides turn the TV on (change channels, etc.)? Hope this helps and good luck!
Mar 15, 2010 | Emerson SpongeBob SquarePants TV
My children have spongebob t.v but they have lost the remote controle to it ! how do i get the t.v to play the dvd player if i dont have the remote ?
you cant. go to radio shack and get the RCA 4 device remote model #RCR4383N $10.00. use the directions to program it automatically. just did my son's tonight, works like a charm. use the input button at the bottom to switch to and from AV input.
Nov 05, 2009 | Emerson SpongeBob SquarePants TV
Key lock on turn off lott the remote
i might have hit the key lock by accident and cannot get the dvd remote to work. Any solutions???
Sep 24, 2008 | Emerson Dora The Explorer DVD Player
Remote for the spongebob dvd player
You can check on RCA.com to see if they carry a remote for that player as a part (usually they do). Can you tell if there is anything wrong with the infrared sensor on the dvd player?
Jul 13, 2008 | RCA SpongeBob SquarePants
Buttons on front console no longer work.
time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Feb 08, 2008 | Memorex MVD2027 DVD Player
Spongebob DVD
well first ,there still some remotes available at this website ( www.ebay.com ) write SPONGE BOB REMOTE CONTROL.
AND . . . for unlocking the key , I suggest to go to MENU and go where it says SETTINGS , HOPE THIS HELPFUL.
Jan 20, 2008 | Emerson SpongeBob SquarePants TV
Emerson SpongeBob SquarePants TV Logo
321 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
