Question about ION Audio iTTUSB Turntable
I connected to the computer I turn on the turn table but no sound
No manual on how to use the turn table.
  • patlunabope Jan 03, 2009
    I don't understand, I have to be a member of a e-mail listing to get more info or douwnload the manual for this turn table if I could returned I would do it but I bought it one year ago and I just started using it.
    President:
  • 379 Answers
Http://www.ionaudio.com/contentmgr/showdetails.php/id/1089/tt/4
I found a link for the table , but they want an email address , to download the manual . good luck
Posted on Dec 25, 2008
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - did this information FIX YA ? thanks for voting .
Just bought a LG home theater system for my TV, my model number is 247FHD-T11, the theater system uses and hdmi cable, but my tv has not connect, what am I doing wrong?
It appears that television does not use HDMI to connect audio, only video. Sound is via twin phono leads. Here is the page in your manual.
Olevia 242T FHD User Manual Connecting To Home Theater System Or Earphone...
Table of Contents
Olevia 242T FHD User Manual Table Of Contents
Setting up the Sound Quality. Look in the settings to see if an Firmware update _may_ have included HDMI audio output.
Olevia 242T FHD User Manual Audio Osd Adjusting Sound Quality Description...
Apr 19, 2017 | LG Audio Players & Recorders
Record player turn table and needle not communicating
1. Check that the cartridge is fitted to the arm properly because if there is a bad connection you will get no sound.
2. If properly fitted to the arm there may be a problem with the cartridge the stylus is mounted in. You basically have to trace it back from there.
Most of the new lower end turn tables I have seen on the market are pretty shoddy and if people are having problems with them I am not surprised. You pay big dollars for a good turn table now like the Thorens. If you want a good turn table that will last a lifetime and be 100% reliable with excellent sound that is what you need to buy.
http://www.thorens.com/turntables/drives.html
Dec 26, 2015 | Audio Players & Recorders
How do I connect my turntable? I have tried using the slots for auxiliary, with an Onkyo turntable with standard plugs. Do I need a special adaptor?
Auxiliary will work but its not intended for phono ( record player ).
The turn table doesn't have a amp so the sound will be lower.
Where as auxiliary is designed for digital connection ( mp3 Laptops etc ) that have they own pre amp.
all the turn tables I have use need to be Earthed to the amp via a earthing tag or you will get a bad sound.
Hope this helps.
Feb 23, 2014 | Sony STR-DE685 Receiver
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
Ive fitted a pre-amp for my turn table and still dont get sound how do i know if my turn table is fitted with a magnetic cartridge
Touching the wires that connect to the cartridge, once it is disconected, and still connected to your amp should cause a buzz on two of the wires (left & right) the others are earths and won't make any sound. If you don't hear anything then there's something wrong with either the wiring or the pre-amp or your amp! If you do hear the buzz the cartridge is dead. You can replace it with any suitable cartridge that fits into the headshell of your turntable. With this test it doesn't matter if a magnetic cartridge is fitted or not. Because if you don't hear the buzz, well you know the rest....
Jun 26, 2010 | Audio Players & Recorders
Turntable not turning--new computer installed at 300.00 -was turning when repairman left-not working again today--
Check your owners manual as some turntables can be turned off by a switch on the control panel. If not, the turn table connections may have come loose from the control board or the motor could have died..
Jun 20, 2010 | Thermador MBBS Microwave Oven
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Beeping and not starting
in the manual of the computer, at the BIOS section, there should a table with what each type of beeping sound means ... (probably something got busted ...)
U can try to remove and reinsert/connect all components, in case that the cause of the problem is just a faulty contact ...
Jun 28, 2008 | Compaq Computers & Internet
CDP-CX300
Get a service manual or pro to get this taken care of. It's a timing issue..accordianman
Nov 24, 2007 | Sony CDP-CX300 CD Player
ION Audio iTTUSB Turntable Logo
171 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Ben Armstrong
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
