Question about Xerox CopyCentre C118 Copier
Xerox M15 The copier shows "Heater Error" but the heater lamp is good. How to solve the problem? Thank for your urgent help. Could you let me have the technical manual service for this copier? Thanks!...
  • mangesh_kute Jul 04, 2008
    Printer is showing "heatre error".
    Fuser and LVPS are new,please tell me right solution.
Check the board around the battery, there are some line broken
i had this problem and i fixed it
Posted on Apr 20, 2010
  • 163 Answers
"Heater Error" doesn't just mean the lamp is faulty. It may actually be getting too hot due to a dirty thermistor or thermofuse. Clean those before going any farther.
Posted on Apr 23, 2007
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
I HAVE A M20 XEROX PRINTER AND I AM GETTING A MESSAGE THAT SAYS OPEN HEATER ERROR WHAT DOES THIS MEAN
The heater rod (quartz lamp) inside the fuser roll is cut/ burned. Unfortunately Xerox will not support it as spare. You should buy a new
fuser.
Replacing it is easy. Just a few screws to take off on the right side plus two electrical plugs.
Oct 03, 2010 | Xerox WorkCentre M20 Black and White...
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
Problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Jun 04, 2009 | Sharp AR-M237 Copier
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Copier won't fire up
your fuser unit is not working .open and see your thermofuse, thermistor or your heater lamp is out. if there is dirty between your thermostart & your fuser roller, clean . check for continiuty on your thermofuse & fuser lamp. thanks
Nov 12, 2008 | Office Equipment & Supplies
Xerox workcentre c2424 error 37,008.4x
Most likely yes. That contains the power supply for that heater.
Oct 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Error Code : 6-355
06 xxx on Xerox products {I take it it is a Xerox?} refers to Scan or illumination...does the scan carriage under the glass move up and back a short way? Does the lamp come on? That's your starting point
If the lamp fails to light you could get someone to check continuity of the lamp and the overheat thermostat on the carriage (these are usually a push to reset)
Be SURE to unplug from the power, you can still get a bite from the lamp heater even if switched off!
Aug 22, 2008 | Xerox DocuColor 12 Color Copier
Fault 37,008,44:21892
Printer paper preheater is open cct. The machine has a seperate drum heater
Jul 02, 2008 | Xerox Phaser 8500/DN Printer
Xerox CopyCentre C118 Copier Logo
189 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
