Question about Vivitar 2000 Flash
Vivitar 2000 with canon xs
I have a vivitar 2000 and would like to know if it is compatible with my new canon xs. It seems to work fine but I have heard that the vivitar put out to much voltage for the canon. I was told the canon take only 6 volts but the vivitar puts out approx 58 volts. 4 batteries at 1.5 v works out to 6v, I am a little confused. Can you solve this problem
  • Anonymous Feb 01, 2009
    Same problem. I used to shoot with a vivitar SLR and recently got a canon rebel xs. I love my new camera and was wondering if I could get away with using my old vivitar flash and not have to purchase a new one.
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Posted on Sep 26, 2009
Will it work with my canon rebel xs
You must make sure that the voltage of the flash gun is not too great for the camera if it is then you may damage your camera electrics. Test it using radio triggers off camera.
Dec 18, 2015 | Vivitar Auto Thyristor 2600 Flash Unit 4...
Old vivitar lens to adapt to a new digital camera
The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
Mar 28, 2008 | Cameras
Is this lens compatible with a Canon Rebel XS digital camera
Sigma makes lenses with a variety of mounts to fit a variety of cameras. If the lens has a Canon mount then it will work with your XS. If has some other mount, Nikon for example, then it will not.
Jan 10, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Is Vivitar 1900 electronic flash compatible with canon eos 550d
You have to measure the trigger voltage on the pins of the flash with a voltmeter to make sure it is at 8 volts. If it is higher, you will fry the Nikon. Use the center pin and the one at the edge of the shoe to measure the voltage.
Aug 08, 2012 | Vivitar 1900 electronic flash Flash
My old memory card was busted, so I ordered a new one and a couple backups of different memory cards. It says that I need to format the cards, which is what I was expecting, but it keeps saying that it...
If your old memory card was "busted" is it possible youhave damaged the memory card holder/reader in the camera?
Anyway, seems memory card problems are not uncommon with this camera.
It might be worth your while to have a look at http://web.canon.jp/imaging/eosd/firm-e/eos
This enables a firmware update which may (or may not) fix your problem.
Sep 08, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Vivitar 285HV flash and I'm wondering if the firing voltage is low enough to use with a Canon Rebel Xs digital camera?
According to Vivitar, the 285HV has a trigger voltage of 12V, which should be safe for use with modern digital cameras.
Mar 22, 2011 | Vivitar Cameras
Is Vivitar 2000 Electronic Flash compatible with Nikon D5000?
Well I found the Vivitar 2000 auto in a thrift store, and it seems to work perfect with my Nikon D5000.
Oct 31, 2010 | Vivitar 2000 Flash
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Older Vivitar Flash for new Canon SX10
Not compatible.
Get slave triggers and use them as remote flashes, or buy another film camera.
It seems Vivitar no longer is in the flash business. Get a Sigma or Sunpak digital flash for your SX10
Aug 28, 2009 | Vivitar 285HV Flash
Vivitar lens
Can you provide model on the Vivitar and the model of the Rebel? The serial number provided is not sufficient to find exact info on the lens mount. If you take a picture of the lens mount and upload it, it's better.
Best info I can give is this ...
The Canon Rebel is an EF mount and will accept also EF-S type lenses. Once you have the mount type of the lens, you can then locate a mount adapter that will allow you to attach it to the Canon.
For example. If the VIVITAR lens has a T-Mount, then you can get one here. Realize though that old lenses do not benefit from new camera features, so autofocus and other things may not work.
Let me know more info if you can ...
Hope this helps, if so, rate a FixYa! ThankYa!
Nov 26, 2007 | Cameras
Vivitar 2000 Flash Logo
421 people viewed this question
Top Vivitar Cameras Experts
Steve
Computer Links
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
