Question about Oregon Scientific WR108 Weather Radio
Turning off alarm
Read the pdf instructions....can figure out how to turn off the alarms - both are currently on. i toggle through to the alarm set times but never can find the -:--. ive tried all combinations of buttons that i can think of. when left at 0:00 - they sound off at midnight. thanks joe
  • Anonymous May 25, 2009
    I can not turn off the symbol for the alarm. I press menu untill set alarm comes up and then press menu again and one or two flashes. The instructions say to press up or down button till disabled symbol shows but it just goes from 1 to 2. Hope you under stand the question.
    greenacre@ns.sympatico.ca
Step through the data/time by tapping the MENU button. you should see date->alarm->alarm1->alarm2
when you get to the alarm displays, use the arrow keys to select -:-- . Hope this helps.
--dio
Posted on Jan 11, 2008
Cannot delete alarm setting. It beeps every morning at 7:00 am
Look for an alarm button and see if the display indicates that the alarm is off. If no alarm button, you should toggle through the settings until you see the alarm settings. As you toggle through, the alarm should be turn off. For more help, please provide your manufacturer, make and model of what you need help with.
Mar 04, 2015 | Measuring Tools & Sensors
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
I did not get any instructions with my son's ben10 four arms projection alarm clock, and cant figure out how to even set the time, does anyone have instructions please
Hi
Hopefully you've figured this out by now, but if not then I hope this helps.
Alarm Setting - Press Mode twice to change the alarm time. Set switches between hour and minutes and Adjust changes the time. The alarm is on when there is a symbol at the top right on the display. Press and hold Set then press Adjust to toggle the alarm on or off.
Time/Date Setting - Press Mode three times to change the current date/time. Use Set to move between the hour, minutes etc and Adjust to change them, as with the alarm.
Pressing Mode once accesses a stopwatch function. Adjust to start/stop and Set to clear.
Dec 25, 2010 | Toys
GE 7-4894A Need instructions on how to set the alarm.
The manual is at http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Jan 16, 2009 | GE 7-4894 Clock Radio
Jensen JIMS-225 instructions
while the docking station is in sleep mode or off not playing any music on the remote click the set button twice an alarm clock icon will appear and you use the volume buttons and the skip track buttons to set. To turn the alarm off hold the snooze button down until icons disappear. I lost the english version of my instructions but still have the spanish and can kind of figure out what it says still. Hope this helps
Dec 23, 2008 | Audiovox Jensen Universal iPod Docking...
GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
Dec 19, 2008 | Nike Triax Fly WK0006 009 Watch
Oregon Scientific WR108 Weather Radio Logo
453 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
