Question about KitchenAid Kitchen Ranges
Kitchen Aid oven is not working and is putting out a code
Oven is gas and elec. Went to put on the oven to preheat then got code number 0100 then it said AM71-UN75-EEKGO-097 Oven gas will not turn on. We can hear the igniter working to light and for a sec a little gas. but the element inside the stove work fine, just that we can smell a little gas as if it was to light its self.
    President:
  • 373 Answers
The Controller is asking you to set the probe temp because it thinks the probe is plugged in try to plug in your probe and remove it and see if it goes away if not the probe outlet is bad
Posted on Dec 25, 2008
  • Suresh Thrithandam Venkata Lakshmi Narayana
    hi henry, we had a earlier.that jack probe you found unconnected goes into the torx screws
    check out the following link, i have already given it to you earlier
    http://www.appliancepartspros.com/partse...
    select diagram 2 on the left side. then on the display you can find part 22 which the the jack probe you found and it goes into part 21, those are the torx screw.lower you can even select the image of the torx screw.hope this helps you out.
    awaiting your comments.
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 · Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
It take a long time for the oven to preheat and some time you can smell gas during the preheating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Amana RanARG7302 Gas Kitchen Range
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
This morning, I went to turn the oven on to preheat. The oven light came on, but when I passed 250 degrees, it went back off. I turned the knob around to broil, the light came on again. But the oven never...
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Nov 29, 2009 | Kitchen Ranges
Kitchen Ranges Logo
158 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
