When i click on the icon for the stylin studio its comes on the screen to big and the only thing i can do is take a picture and then then picutre dispear.i cant see around on the sides of the screen its to big
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
You should organize the files and folders, as this makes scanning easier. To do this,
Slide the USB switch and connect it to the computer via the USB port (Make sure "USB Connected" appears on your computer monitor and if not, double click the "Media Studio" icon on the desktop.).
Click the music note icon and a music display list will pop up.
Click "Add Folder" under "Media Studio" and the "Open Folder" window will pop up.
Select the folder you want ot add and click "OK" (the files of the folder selected are added to a list on the left side of the "Media Studio" screen.
If you want to add a file, click Add File" under "Media Studio" and the "Open" window will appear.
Select the files you want to add and click "Open" and the files are added to a list located at the left side of the "Media Studio" screen.
If you did the complete install of the software, then the program is there, you just don't have a shortcut icon on your desktop. You'll have to click on "start" then find the folder that contains your imaging studio software executable file (when you double click on that icon, imaging studio comes up on the screen). resize the window so that you can see part of your desktop behind the current window, left click on the executable file icon and drag it to the desktop and release the mouse button. Click on create shortcut and you'll have an icon for your imaging studio on your desktop.
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
The resolution on your screen depends on how big the LCD screen is
On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Hello
Your TV is not getting any signal at all to process, or the tuner inside your TV is faulty. Blue back screen comes, when there is no signal to any of its input or faulty tuner. Just connect the tV with any other video source, like VCR or DVD , connected to its AV terminals and set the tV to take input AV, and check whether picutre comes in or not. If picture comes with AV connection, make sure that your tVs tuner is faulty and should be replaced. If no picutre comes with AV connections too, the Chroma Ic insie your TV is faulty, and should be replaced. OK.
My daughter's was doing this. I made the changes to Flash suggested on http://www.girltech.com/forums/Default.aspx?g=posts&t=713 and reset my screen resolution to 32 bit. It now works (albeit slowly).
Swear I don't work for Mattel or Girltech, honest.
well maybe the picture you took is too big to display on your screen ? try recropping it you can do this by selecting options on the picture and then edit .
