Question about Palm Treo 750 Smartphone
Phone rings but can not hear or be heard on phone
Just received phone
    Problem Solver:
  • 18 Answers
Is it muted?
Posted on Dec 25, 2008
Cannot hear anything on the receiver, nor can anyone hear us
The cable from the base unit to the handset may be faulty or not properly inserted,
Sep 21, 2014 | Aastra Telecom Powertouch/Vista 390 Corded...
In my mobile 5320 xpress music the ringtone sound is not playing . but when headphones is plugged in , the ringtone is heard in the headphones. bit when removed , the ringtone is not heard.
Hello,the problem you are could be caused by so many thing,but i will love to know if the phone does ring out if you are called,and also when yo receive calls do you hear them,if the phone does not ring,i advice you buy a new ringer because the one you have in there is definitely damaged,and if you don't hear people when they call,that means you also have problem with your ear piece which you can replace by getting a new one at a mobile phone store.
The phone could also face a jammed application problem or a virus attack,which means if it is flashsed you might have it working as supposed.
wish you good luck,
take care.
Dec 05, 2010 | Nokia 5320 XpressMusic Cellular Phone
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
Jan 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
VOICE CANNOT BE HEARD WHILE MAKING / RECEIVING CALLS
have you replace the spiral cord of the handset? if you do may the handset is defective, try replacing the handset, if you have extra unit try to borrow and connect it to your phone just to see if its good or not.
Jun 21, 2008 | Panasonic KX-T7730 Corded Phone
Can't hear the Ring
Hello, Push the center button(in the middle of the four directional arrows). Scroll over to the screwdriver/wrench icon and select it. Scroll down to the "Audio" line and select it. Scroll down to "Loud Detail" and select it. Set "Ring Volume" to a higher number(I use 7). Have someone call you and you should be set. If this doesn't work, with the phone open, look at the two buttons on the left side of the phone, push the top button until you have your desired ring volume. Good luck!
Jul 26, 2007 | Motorola Mobility V710
Voice sound has gone on phone (but ringtones and all other sound working).
there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
Jul 02, 2007 | Panasonic G50 Cellular Phone
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
Palm Treo 750 Smartphone Logo
64 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
