Question about Acer NSK8458AN Keyboard
The keyboard on my notebook is locked in some way that the letters cannot all be typed without holding down the Fn button. The light next to the Caps lock light is on, and it seems like it is the light of the lock? what should i do to unclock it?
Hey..
i had the same problem (and it was verrrry annoying lol).. to unlock it. press the Fn key and then the Num lock key =)
Posted on Jan 09, 2009
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
Number locked letters become numbers
By pressing and holding down the Fn key which is located at the bottom left hand side of the keyboard next to the control "Ctrl" and press the F11 button will revert those numbers back into letter and pressing and holding the Fn key again and press the F11 will turn them back to number. Any further assistance please ask, Kronoguy
Aug 13, 2011 | Acer Aspire 4315-2963 Notebook
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
Keyboard Produces Numbers Instead of Letters when Num Lock key is on. For example here is what I get when pressing the keys from Q all the way over to the \ key on that row of keys when I have the caps off...
I have the same problem. Click the Windows start button. At the bottom is a Windows Serach box. Type 'keyboard'. A virtual keyboard appears. Click the NumLock key on the Virtual Keyboard. This should override the issue you are having and your keyboard and keys should now work. Otherwise reboot!
Feb 16, 2010 | HP Pavilion DV9910US Notebook
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
I am having to hold down fn to get my keyboard to properly type letters i pressed num lock and it still isn't fixed.
go to start menue>
all programes>acccessories>accessibility
then on "screen keyboard"
there you will see the numlock button hilighted.
single click on num lock key.
ur problem is solved.
dont forget to vote
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
Fn option appears in place of letters on keyboard
Sounds like you need the keyboard replaced...
Jan 08, 2009 | Acer TravelMate 2300 Notebook
Keypad
If your keyboard features a special key "Fn" Do this: Press Alt + Fn or Fn + Caps lock. If it does not apply....you should have a special that helps you activate special fuctions noted on your keyboard. You have to find that key. Holding it down type the problematic keys. You will get it right.
Oct 05, 2007 | NEC Versa SX Notebook
@nd function on keus
It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
Mar 28, 2007 | Sony VAIO VGN-FS640W Notebook
Acer NSK8458AN Keyboard Logo
309 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
