Question about Frigidaire FDE336RE Dryer
I'm trying to get a partslist w/ diagrams for my frigidaire dryer model FDE336RES1. Do you know where I can go to print these up?
    President:
  • Frigidaire Master
  • 2,651 Answers
You can enter you model number here http://www.searspartsdirect.com/partsdirect/index.action
Posted on Dec 25, 2008
Dryer not drying
Hello Tony Palow - Have you recently cleaned the ducting? Confirm that it doesn't have any debris or build up. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the unit still does not dry, I would recommend contacting a professional to proceed further since it could be any one of several underlying causes. Most than likely the dryer has a faulty control board, heating element, blower assembly, thermostat, sensor or damaged cord.
Mar 18, 2013 | Frigidaire Electric Dryer
Were is the thermal fuse located on the frigidaire fde336res1
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
http://www.youtube.com/watch?v=wkog1i53T_k&list=UUKBjalPycKRmo4Mz9vRsydg&index=10&feature=plcp
http://appliancejunk.blogspot.com/2011/08/frigidaire-gallery-dryer-revamped.html
The smaller disk is the fuse. If blown the dryer will not run
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 07, 2012 | Frigidaire Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
My frigidaire dryer model FDE336RES1 gets hot and shuts down. What should I do to repair?
Check for clogged vent duct. If this does not solve the problem then the limit sitch is out.
Jun 30, 2009 | Frigidaire FDE336RE Dryer
Door switch isn't working
Hi, Is the switch a two or three wire?
Please let me know so I can try and assist you.
Thanks
Vic
May 24, 2009 | Frigidaire FDE336RE Dryer
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
FDE336RES1 frigidaire electric dryer
bb8c47e.jpgThat squeak can lead to a full blown drum failure into the heating element fiasco. Better pop the top and get thront off. Remove the drum and inspect the ball before it goes bye bye to China.Oh and while you are at it you may as well check the front glides
05b09de.jpgYou can start here
Jan 03, 2009 | Frigidaire FDE336RE Dryer
Frigidaire dryer model #FDE336RES1
The Thermistor is defective, you could get it online.
Feb 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
135 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
