Question about Whirlpool Duet GHW9150P Front Load Washer
Washer sporadically floods the floor!
Only sometimes, and I haven't figured out when, my Whirlpool Duet washer floods the floor. It usually manages to finish the complete cycle, and only rarely it doesn't even finish draining and spinning. It first flooded the floor after I had only had it 15 months, and it happened about once every two months. Now at 4 years old it is flooding about every 2-3 weeks. I run about one load a day. The water is not sudsy but clean so it's probably from the end of the cycle. It is a lot of water, and appears to be the whole drum amount draining - somehow onto the floor instead of out the hose, but NOT every time. The wall is NOT wet where the hose tucks into the drain. It floods randomly, and I haven't been able to connect anything with it. It usually only floods once, and then not again for awhile. Has anybody had a similar problem?
  • 3 more comments
  • mismanagemen Dec 26, 2008
    Exactly the same started happening to me about two months ago... literlally just looking for a Duet manual to see if i can fix the problem... anyone got an answer?
  • ckschoch Dec 28, 2008
    The mystery is why this happens only on occasion. I have been having the same trouble and am eager to learn the solution.
  • cboswell123 Dec 29, 2008
    I have the same problem. My front load duet is almost two years old and I'm ready to take it to the local dump. It leaks unexpectedly, and does not clean my clothes. It has been the source of many a dispute in my household for the past two years and I can't think of a worse purchase than this. Today, one of the plastic arms inside the drum came off. I give up. I will be buying a new washer this week. I hope you have better luck than we did, what a wasted $900.00. I think I will go back to a standard top load,non digital washer. Cheaper and my experience, is they actually clean your clothes. I'm tired of dingy dirty clothes that have a foul odor. I thought I was probably imagining some of this problem until I googled the problem and found other having the same problem.
  • bkbrowning Dec 29, 2008
    I have the same problem. About every few weeks, the washer floods the floor. Here's what I have diagnosed so far:
    1) We first noticed that our clothes were not ending as dry as they had previously. At first, I thought it was a problem with the washer draining. I investigated the drain pump and removed and cleaned all of the seals/tubes. Draining seemed to be just fine. It seemed "fixed" so we moved on.
    2) We had a few minor repeats of #1 above. Again, nothing major, but it seemed to be inefficient draining as the clothes were occasionally wet.
    3) We have had 3 incidents of water on the floor in the past 4 months. Each time, it is enough water to fill up the wash basin an cause a leak under the front door seal. It will eventually leak enough to completely cover the washroom floor in water. Again, I thought it was a draining issue and re-inspected and "fixed" it.
    4) Getting serious about his now, further investigation showed that this was only occurring after we had left the clothes in the washer for an extended period of time after the wash/spin cycle had completed. If we took them out right away, they were much drier than if we left them in the wash basin for a period of time after the cycle completes.
    5) Today, we again had water all over the floor. This time, we had not even used the washer! No clothes were in the wash basin. It was full of clean water and had filled to the point of overflowing past the front door seal.
    So, I think that I have been chasing the wrong problem. It doesn't appear to be a draining problem...it appears to be a filling problem. The washer is adding additional water to the wash basin! This would account for the wet clothes and the occasional spills all over the floor. So, how does one diagnose and fix a "filling" problem? Could it be that our filling valve is stuck slightly open?
  • jdtech May 11, 2010
    Check the bellows it is a rubber gasket that seals the tub and the door. Put your hand around the inside of the bellows and check for foreign objects. The bellows tear easily if cloths are washed with small sharp objects in the pockets
catriver
  • 878 Answers
SOURCE: Flooding
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Posted on Jun 18, 2006
jsrock516
  • 5911 Answers
SOURCE: flooding! Help
This is usually a symptom of a pressure switch malfunction. The pressure switch is located in the operator console behind the load (or water) level knob. It is cylindrical in shape and has an electrical connection and an air hose attached to it. In many cases, the only problem is that the air hose has come loose and fallen off the fitting on the pressure switch. All you have to do is reattach it. HINT: placing a small zip tie around the air hose where it connects onto the pressure switch will create enough resistance to keep the hose from vibrating loose again. Just a snug fit will do. Over tightening can break the fitting on the pressure switch. You will need to open the console and inspect it. To open the console, it comes off in a few different ways depending on the year and model of the washer:
1. If you have removable end caps on the console, they simply pry off by lifting from the the back exposing a screw under either end. Remove the screws and the console lifts up.
2. If the end caps do not come off, place a putty knife in the front corner of either end of the console where it meets the washer top and push in while lifting up. This depresses a retaining clip and the console will lift up.
3. Some consoles have a screw located on either side in the back that you need to remove and it will then lift up.
Be careful when you lift the console. There are small plastic hinges holding it in place and they can break if you aren't careful. Place the console in its resting position by laying it over the back of the washer. The pressure switch will be easily accessible. Double check the hose like I previously stated and double check to make sure all the electrical connections are in place.
If you check the switch and find that everything is in place as it should be, you may have to replace the switch. Post back with your COMPLETE model number (located around the rim of the washer tub opening) and I can track down a part number for you.
I hope this helps.
Posted on Apr 11, 2008
SOURCE: Kenmore 970-C45 072-00 Front Load Washer ( 2 year old washer)
check the pump
Posted on Jul 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer fills with water when not being used
Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
If you need to replace the water inlet valve, replacements can be ordered on line at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
It is a very simple process to replace. Just follow these steps:
1. Shut off water supply and unplug washer.
2. Disconnect fill hoses from the back of the washer.
3. Remove washer top panel by removing the three screws that hold it in place in the rear. With the screws removed, the panel slides back, then off.
4. The water inlet valve is located in the left rear of the washer (as viewed from the front with panel removed).
5. Disconnect the dispenser hose from the valve and the mounting screw(s) and the valve is removed.
6. Install new valve using the steps above in reverse order.
It really is a very simple repair. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Nov 18, 2008
SOURCE: whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
What do I do when the big spring that is seemingly behind the rubber bladder of the the door opeing keeps popping out on my Whirlpool washer Duet?
that spring is for the door water seal if it "pops" off when you have a load of washing being washed you will flood your kitchen floor with water,,,fit a new door seal and a new spring fast!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer tub filled with water, did not spin, over flowed, and partially flooded my floor. The final spin cycle did remove the water out through the hose. How can it be fixed?
the pressure fill switch has become disengaged....remove screws holding control panel and raise it up,you will see a plastic tube has become disconnected and must be reattached to a component directly under load size selector switch,usually a rust or orangeish color,sometimes white
Mar 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer's cold water valve is stuck, causing flooding. How do I fix it? And is it considered a washer problem or water problem?
Yes, usually this problem IS caused by heavily mineralized water and sediment from your water supply, it onlys takes a small amount to jam the solenoid. It is more than likely that the only way that you can solve this problem is by replacing the water valve. Since your washer calls for water at different times it would be impossible to shut the water off, once full, AND still have a normal wash cycle. Depending on how badly it has flooded the area, there may be more damage than just the water inlet valve. I would contact a technician to ensure no further damage has occured. Hope this helps .
Thanks
Dec 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer over fills and floods the floor
Morning. There is a Water fill level switch in your unit that monitors the level of the fill process. this switch is malfunctioning and, it will need to be replaced asap if possible.
Jun 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sports unbalanced...
be sure the 4 screws that hold pedistal to bottom are tight ..next lower washer all the way down run all 4 feet up as far as possible next adj front legs until washer is firm on floor and has no motion when manually rocked ..tighten lock nuts to upper limit of legs to keep them from backing out if still have excess motion try adj 1 leg at a time while in spin ..also possible weak floor ..these machines are quite heavy and need solid flooring..also machine may rock some at low rpm but usually steady at max
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
